help-wira suspension
godgirl
34
1,508
i wan to lower my car...
i need to cut shorter the ori spring better
or change wif one set sport spring better ?
i wan my spring more hard cause i hv touge(play play) wif fren...
n i oso use it as home use...go school n fetch fren...
which is more good...
cut is cheaper
change is more expensive
cut or change ??
gagek7
117
5,018
seremban/tambun
bro i got 1 set wira sport spring simply change with yours,no need your money.just give me your standard spring.can?
but mine is for wora 1.6...how?want aaa....?send me pm if agree.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
DO NOT CUT... i repeat... DO NOT CUT UR ORIGINAL SPRINGS...
sorry for my harshness... but if u want abnormal steering feedback and rollercoaster ride, pls go ahead with it....
so my verdict is, definitely change sport springs better....
godgirl
34
1,508
but do the sport spring is hard and can use for long time...
bcause my ori rear spring when i fetch 3 ppl...it get down near touch the body...if sport spring not harder than ori...my car !!!
seanlee
382
3,018
as what sky said do not cut stock spring...
Stock spring is mean for soft....sport spring will slightly harder then stock for maybe 10-30%....
just less then Rm500......but also advice you to change with absober as well...i suspect your absober kong also.
GT_AUTO
3,501
71
1,648
K.Trg
www.facebook.com
yeah lor...why must cut when sport spring nowadays is so cheap compare
to 10 years ago.sumore sport spring is 10-30% stiffer the stock like seanlee
mention above.
godgirl
34
1,508
adjustable how much..
i think b4 to change to adjustable...
seanlee
382
3,018
depends on your budget...
Zth also got alot people selling.second hand..
normal price should be RM1500-1800...
but too bad you not in KL..then i can bring you to my tuner shop to get your question answered.
godgirl
34
1,508
u plan to giving me wat answer...
viostar
475
2
Hey bro,
better don't cut your ori stand spring.....
I got sport spring 1set apm perfomax red in color..... 2nd used around 1yr.
If you interested... just pm me.
amad108..
418
5,018
the reason why sport spring harder then ori coz they want use same load but lower ride that's why... they can be calculated (but lazy to find in my book)...
and spring are lifetime period usage (if u not ever overheat or cut it la)..
for adjustable abs really can do tight corner, but the diffrent btw good and not so good abs adjustable is how they absorber the vibrate but still can corner really tight..
Hi guys
What is the function of vacuum hoses for throttle body? What are the alphabets P, E and A indicates and are the hoses installed here correct (2 hoses connected to P and A only, not E)? Please, need some advice. Thanks all!
