Increasing turning radius?
Cow
1,090
Is it possible to increase a car's turning radius? My car's turning radius is really small, hence making really sharp u-turns and 3-point turns sometimes turn into 5-6 point turns.. lol
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
simple.
1. hard pedal a bit
2. prepare to pull/push ur emergency brake
3. pull/push ur emergency brake at the right time
4. pedal to steel, feel the slicing feel at the rear tires
5. keep the steering back to normal/straight
6. the front will pull the rear into normal track
7. 1 point U-Turn is complete.........:biggrin:
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
Can increase, but not many people would mod it. Only drifters like to mod the streering turn in angle. I'm not sure is any mechanic here does it. But i'm sure some drifters here does it.
just make a few more of the teeth on the rack...
GoldenHawk
777
...and let the tires scrape your inner wall? I think it's requires more than that. Offsets & shaft layouts have to be considered. PLEASE get a professional to do it.
huakenny
LB Performance
9,126
240
Kota Kinabalu
i not sure wat is ur car..
some car can get a steering rack assembly from chopshop n fix to their ride...
if ur current steering rack/pinion gear is small...then u gotta find a bigger one...this wil improve ur turning radius.
for example, impreza wrx can put in STI version steering rack n pinion set...it will improves the turning radius as STi gear is bigger than wrx.
for other car models, i not sure..
cheers
Cow
1,090
ooohhh, hmmm..dunno whether got such thing for my car or not.
is it costly? the rack and pinion thingy from chopshop
satria_95
6,746
18
5,138
Malaysia
jineil,
hahaha I do that quite a bit of times but when you don't have enough run way to sprint your car, then end of story. 6 point u-turn again. hehe
tajulsans
1,449
9
Soo Bang
i think u wanna reduce it rite?? to make u turn easier?? well what u can do is adjust at the tie rod so that your steering favor to the right.. makes U turn better as mostly our u turn on the right side but at the expence of worst turning on the left side le.. kekekek
huakenny
LB Performance
9,126
240
Kota Kinabalu
tie rod cant adjust le...it only can adjsut the freeplay...
if ur turning radius for left side n right side is not equal...then tat is alignment problem....
to reduce to turning radius...u hv to replace a bigger pinion gear in the steering rack assembly...
but normaly here just buy the whole thing n change la...easy
wat car le?
Joeker
Walking Dead
3,580
62
Jinjang
Cow,
It depends on your steering linkage, whether its rack and pinion or LM ball screw type design
Also depend on your steering castors design
So basically the guy who is to mod your steering angle needs to look at your car's steering linkage before deciding whether its possible or not.
Here is pic of a car who has done the steering angle (for drift angle purpose)
The steering lingkage design on the car in this pic was rather simple and straight forward (newer cars tend to have more complex steering linkage for comfort, handling, etc, etc) therefore the amount of work to mod it was not complicated.
Cow
1,090
ohhh, so "smaller turning radius" means less effort to turn? hehe ok ok my bad :P any mods want to edit the title of this thread? *paiseh*
huakenny: it's a hyundai coupe only ler
joe: oohh, thanks for the info man...I think I roughly know what to do now...
Hey people i'll like to find out if a mitsubishi 4G63 SOHC could fit in a nissan micra ??? I would like to know if that's possible?? Or should I go with a GA15 sentra engine????:hmmmm::hmmmm:
