Gearbox F5M222VVKF
ali_civet
268
Anyone can give the info about the above gearbox ???
Its a mitsu gb...
Which engine/model its from?
Ratio??
Can its perform well with my 4G93p???
Anyone got the info??
:regular_smile:
boyzone
2,669
5,148
actually it is same with 4G93p gearbox.
Final gear is 4.322.
ali_civet
268
Thank Bro boyzone...
But OEM 4G93p gearbox code is F5M222VRXE....
any difference from this GBox (VRXE vs. VVKF)??
Did anybody got manual/spec/ratio table of this VVKF GBox??
dagger
103
2
3,018
your VVKF has the same ratios as the VRXE gearbox.
1st - 3.363
2nd - 1.947
3rd - 1.285
4th - 0.939
5th - 0.756
FD - 4.322
It states that it's from a vehicle model E55A (not sure which car is using this model, but it's an overseas vehicle type i think)
Reactions: drummydrew
ali_civet
268
Owh...thanks Bro Dagger.
I feel the pickup is better then VRXE...but top I can hit until 190km/h only. My engine just done top overhaul and head polish.
I thought its something wrong with my engine. Why its cant hit 200++
boyzone
2,669
5,148
any idea on ur old gearbox code number? from there we can know what FD u r run before.
ali_civet
268
Gearbox F5M222VVKF vs F5M222VRXE
Bro Boyzone..
Proviously I used OEM wira 1.8 GB F5M222VRXE
tohliang
3,001
www.geocities.com
my 4g93p year 1996 for F5m222VRXE gb , as produced by Proton
TRANSMISSION GEAR RATIO
1st : 3.083
2nd : 1.947
3rd : 1.285
4th : 0.939
5th : 0.777
FD : i'll get back to you soon
Reverse : 3.083
ali_civet
268
1st - 3.363
2nd - 1.947
3rd - 1.285
4th - 0.939
5th - 0.756
FD - 4.322
1st : 3.083
2nd : 1.947
3rd : 1.285
4th : 0.939
5th : 0.777
Reverse : 3.083
its look a small difference there....
but...its any effect on the pick up & top speed???
tkk
1,201
even 2.0cc also using 222 gearbox.
basically what is the different of 222 and 232
nenon
128
guys, wat about F6M211RRBE. anyone got info for this model?
boyzone
2,669
5,148
when Mitsubishi have 6 speed gearbox? I think is F5M211RRBE gearbox.
Is from 4G91 gearbox.
Dear all ZTH sifu,
My honda eg B16A auto for the last few weeks has a serious jerking issue. It actually started months ago but got worse last few weeks. At first it was once in a while then it become more serious and jerk everytime when stop and moving also. The car felt heavy and does not accelerate well. After checking with my mechanic it is due to burn spark plug (again), which i have just change (NGK cooper) in July and less than 3k mileage. Before that my NGK irridium also lasted...
