I see...thanks very much for the detailed reply. I dun usually sprint off the block or go for quick 0-100kmh timings lah. More like just wanted to know the capabilities of the stock car since its a parallel model and such specs are always in fuzzy defines. Would probably do some light tuning just to enjoy the car more. It's kindda like my ideal dream car for quite a number of years before i can afford one recently.howdee,
that SCC magazine is may 2007 issue. (subcribers get it early). should be on sale soon at local book stores.
in teory (on the listed 0-100km/h figures by car manufacturers) . time arent easy to replicate in real world by "normal" drivers.
even lotus elises 5.8 sec (0-100 figures) arent replicated by good drivers (enthusiast) here because several conditions needed to be met. (climate, tires, car+ drivers weight, time of the day, etc).
BUT on ideal conditions & better shifting (of gears), one can come close or meet the quoted figures.
As far as i know someone timed his slightly moded spyder (aftermarket 4-1 exhaust manifold + TRD suspention) to a relaxed & comfortable time of 6.7 sec (G tech II). this was recorded at night however. I am informed by others, our modded spyders (those that took part in local auto X) always sprint out faster than the elise of the block. this is from independent enthusiast views.
getting figures lower than tat one need to FI & have more modded stuffs like lighten flywheel/stronger clutch etc.
however, if 0-100 times are your intention, may i suggest to pick up a aftermaket clutch.
ways to sprint off the blocks for newbies;
1) ride the clutch till higher rpm before releasing it.
2) get tyres with better traction
3) unload as many stuff out from car to lighten cars weight
if im you; forget 0-100 sprints, enjoy the ride. invest on the asset of the car which is the handling /ride.
