Stock wira 1.8 muffler.
Keep the engine stock or only minor mod until u outgrew the engine or u blow it. Then only change to more power. Sometimes a tamer engine allows u to go fast as u can run it to the limit almost everytime.
When I bought VR was 2.0L A/T, mechanic say all in good condition why you convert, use first. 6 months later GB kaput. Half cut GB RM2.3k, Half cut VR4 RM3.5k, that was how VR started ......hahahhaa
From how u word it i can see that;
When u got the car u wanted to mod and already prepared everything which inclusive of budget and 'ministry' approval.People around u also poison u kaw2.
However your mech was 'in the way'. Since u dont want to waste all the preparation you go all out punishing the car hoping for something majorto breaks and u can justify to your mech which u managed to accomplish only after 6 month coz it was a jap car and soo reliable.
There are other version in my mind but i think this is the right one...hahahahaha.
Jap car GB ok, but my Mitsu A/T is same as the Perdana SEi. I think you know how reliable is that GB. In fact the car bought from mechanic's bro in law and under his service. GB was also just replaced that was why he ask me to use first .........hahahahaha
KHNG940413
668
56
johor bahru
LOL. told ya. get the dohc 4g92 and you'll be smiling. hahaha.
what's your current muffler? got photos? need to know your piping spec as well. usually can add another resonator/midbox to quiet things down
This is my muffler. And my friend say the exhaust set up is not normal. Don't know what he mean
KHNG940413
668
56
johor bahru
Juz asking
After changing new rotor & pad thcar stopping power is much more better just when going to 80 & 90 km/h then suddenly stop the braking force is abit soft. Is like you know the car is stopping but you don't have the confidence the car can totally stop that kind of feeling.
Is it upgrade my rear drum to a 1.6 & 1.8 disk make it better or swap the brake line to steel hose type better?
minibeany
598
102
543
Juz asking
also change to double pump servo...
lsm1991
1,469
185
He say is the exhaust layout. He say original wira 1.5 is not like this. Something like that. Since I don't know the original wira exhaust layout I can't say anything.
so basically hes just saying not stick, nothing too crazy.
Juz asking
my 2 sen.... brake lines wont really make a huge dif... not saying there's no dif, just saying its not huge.
the rear disks play a much smaller role than one expects.... also not saying its useless, just saying it wont make as much a dif as one might expect.
the brake pump yeaa... that will make the most dif sint it aint fade we're dealing with. just take note, with a big ass servo comes much clamping power but say adius to your modulation~ some of my incidents were due to bigass pumps in the rain
Juz asking
Let the brakes settle in, take some time to bed in properly.......
Juz asking
Rear disc wont help much.
Certain type of pad esp high performance pad does not work well at normal speed. It takes a lot of heat to get it working. BTW, brake pad need to be run in too. Let me 'baked' your pad...heheheh.
For normal street driving, semi metallic pad is enough. In total, braking rely on other factors too such as tires, suspension, chassis, apart from the brake system itself.
From my experience with my mum wira 1.5 auto long time ago, braking is sufficient. U just need to trust the system and press the pedal slightly more. That is provided the brake system is regularly maintained with fresh fluid, rear brake shoe properly adjusted, using decent brake pad & shoe.
The stopping feeling depends on the car weight, suspension, chassis. Cars like Viva will put on a show when stopping hard from 80kmh. Its throwing mass all over the place. Modern car with decent handling and chassis can hide all these and provided u with a composed body control.
Bigger servo definitely help but too big is bad as braking will be an ON or OFF affair.
sanekit
Dec 9, 2015
1,616
157
oh that kind of muffer with small body memang loud. and yes the exhaust doesnt follow stock route and by the looks of it it's stainless steel piping and got no midbox/resonator. u can add resonator and see if it quiet things down a bit.
sanekit
Dec 9, 2015
1,616
157
Juz asking
most probably the pads doesnt grip that much when it gets hot. what pads did u bought? either the pads or can be brake hose issue. same case, gets hot the hose expand so not much grip. brake servo pump stock one is ok dy for your car. check your brake fluid color if it's clear or murky.
rear disc brake just helps a bit jer. unless u swap full 1.6/1.8 front and back. and proton rear disc after a while brake dust gets around it, when u reverse your car every morning can hear the disc whine. hahaha
Your setup looks like you don't have a midbox/resonator. 4-2-1 then straight to the rear muffler. This kinda setup you can probably add a resonator in the middle to reduce the growl and exhaust noise.
Juz asking
Considering your car is old, I would look at the brake rubber hoses first. Are they still stock? If it's that old the hose is probably expanding causing the pedal feel. Change the hoses to new-stock rubber hoses or steel braided hoses. Don't bother with the servo just yet, make sure the stock system is working before you start messing with aftermarket stuff.
Reactions: minibeany
KHNG940413
668
56
johor bahru
And also I found out that after installing the whole set control arm,the car is a little bit lifted. Juz a little bit not very significant la.
According to reports online, Porsche's new chairman has said that the German supercar builder is evaluating a return to Formula 1, a sport the company left in 1962 due to high costs.
Though Porsche has returned as an engine supplier a couple times (remember TAG Mclaren?), the marque has generally stayed away from Formula One, preferring instead to compete in endurance races and...
