Conversion GSR 1.8 Turbo (4G93T) - Wira/Satria/Putra
niklys
118
18
18
Selangor
have u consider swap stock wiring+ecu+injector to evo3 wiring+ecu+injector?
evo3 ecu can be rechip and tune.:smokin:
im using vr4/evo3/pajero v6 brake set...here some poison, good stuff. confident braking now.
The workshop recommends to use everything stock first. Slowly mod, at a time hahahahah
Is evo3 twin pots same as vr4/pajero/v6? Seems like 4 vs 5 lugs. Caliper looks the same though! Hahahaha
sanekit
Dec 9, 2015
1,616
157
the pads are same. his car using 5 lugs. calipers sama saja..
VR4/Pajero/V6 using same pads?
In that case its the same as the Mitsubishi Delica van oso.
Will be a weird list 'VR4/Pajero/V6/Delica'
Instead of going to the part shop and mentioning we want VR4 pad, we can try to say Delica pad...most probably can get cheaper.
sanekit
Dec 9, 2015
1,616
157
I go PH Auto ask for VR4 pads, he give me Pajero V6 pads......lol
same like subaru wrx 4 pot (non brembo) brake pad same as
-skyline gtr r32 (non brembo)
-fairlady z32
-1st model hilux/land cruiser prado
-nissan silvia s13/s14
and a few others more....
niklys
118
18
18
Selangor
I have one question about my gearbox. It’s worth noting that my gearbox is 4-speed automatic from 4g93t. Next to my handbrake lever, i have a button which signifies power, eco, and hold. Power allows higher rev before gear shifts, and eco does the opposite. But what does the “Hold” button do?
Should be hold it in the gear, not allowing it to change until you disengage the button
sanekit
Dec 9, 2015
1,616
157
like what @vr2turbo said. it holds the gear and not allow the gearbox to shift up. good for steep hills. mine i use back my FWD gearbox buttons. only have PWR and ECO. what i can tell is on PWR, the gearbox is a lot more sensitive on the throttle response. on ECO, mine doesnt let me downshift, and it upshift at 2.2k rpm. ahahaha
I thought both position can up and down shift, only pwr changes at higher rpm......??
leinnz
333
57
3,028
for mazda 2 i own previously, hold button means drop 1 gear down.
lest say D mode, it will use max 3rd gear and wont use the 4th
D3 will use max 2nd gearing.
niklys
118
18
18
Selangor
Alright. Will play around the Power, Eco, and Hold button once car is ready to run. So, Eco modes allows the gear to shift at 2k+-, where as Power Mode allows higher rev prior to gear shift automatically. But Power Mode makes the gearbox more sensitive? Hmmmmm. I believe the throttle control is by wire, unlikely Power Mode would affect throttle response, isn’t it?
Car got smashed in Cheras, 2.30am , took my Sony CD player and remote control. Did not touch the coin box nor the Touch n Go card ....... geez, gonna scout for new cd player now, damn them !
http://img.photobucket.com/albums/v513/digitax/DSC00840.jpg
http://img.photobucket.com/albums/v513/digitax/DSC00839.jpg...
