N/A Proton Brudder
May 28, 2018
26
24
That PNP is a bit crude. You did the sharp edges on purpose?
i had a hard time with just a cordless drill and sandstones to grind with. Did you mean the edges of the outer inlet or the cast marks leftover ? this is 50% prpgress btw. i havent finisbed polishing with wet sandpaper and cloth scrub. plus those damn cast marks are hard to scrape of . must need some kind of ultra powerful laser beam to get it of somehow hahaha.
plz reccomend me a technique. it took me almost a whole week for just the intake mani and havent got to the throttlebody. also i just finished removing the 4g13 and assembling the 4g15 soon. jsut that vdo ecu im still hunting -_-
i tought it should have came out kinda like this guy did https://www.revworksinc.com/assets/images/Graphics/Porting/subyheaderported.jpg
N/A Proton Brudder
May 28, 2018
26
24
also i grinded the inlet to the markings of the new gasket i aligned to it with a sharpie. bit bigger opening is good right ? does it have to me like stainless steel kitchen ware kinda shiny ?
N/A Proton Brudder
May 28, 2018
26
24
And as quote by powerzone :
Powerzone
* For this reason, the intake port is usually not polished to a mirror finish. A slightly rough, satin finish is excellent in promoting fuel atomization thereby increasing the combustibility factor of the air-fuel mixture. The slightly rough surface also prevents the fuel droplets from condensing on the port walls while on their way into the engine cylinder.* http://www.powerzone.co
m.my/tn4.html
This is what I meant. PZ pnp is smooth and rounded edges except the center wall that has a razor sharp edge to split the two chambers. Yours has sharp edges all over.
Casting metal is that stiff huh? Maybe the power of your grinder isn't as good.
I thought inlet manifold is like aluminum alloy only, but alloy already can be harder.....
N/A Proton Brudder
May 28, 2018
26
24
Guys, also can mitsu punya Trottle body pnp with vdo ecu+ harness ? i recently found out that i have a mitsu harness and ecu set when swapping it after i fried my harness due to a short.
my Tb look more like this : https://2.bp.blogspot.com/-NVCUC0MmSK4/UlFFPxNV4QI/AAAAAAAAJqk/DOL5PNjyVlM/s1600/4.jpg
rather than this with more plastic cover thing : https://ehautolink.com/webshaper/pcm/gallery/nm/b8035d8f7cc64337f0ac46b6a5d39a961524119307-nm.png
also down heres is my manifold+TB.Mitsu right ?
N/A Proton Brudder
May 28, 2018
26
24
btw, what's your guys taughts if i swap to Satria GTI VDO throttlebody to the 1.5 vdo . Mapping issues? just adjust idle seed cotrol valve ? imf not mistaken, can pnp.
N/A Proton Brudder
May 28, 2018
26
24
ohh.and still cannot find the SVDO 1.5 ecu locally.if in case its a mitsu thats actually on my 1.4 car with 1.5 swapped block, can it be retunedby a special mechanic . can an AFPR on high pressure compensate for the loe fuel mapping ?
How the heck did your prev mech run a Mitsu harness on a VDO system? There are sensors that the VDO has the MMC does not. If that mech managed to sort this out you should go back to the same guy cuz he's a genius.
Can la. But why? If not mistaken the TB is bigger and if I recall correctly people who did this ended up with "On/Off" throttle. But that might just be a tuning issue. The butterfly plate was too large so even with minimal throttle there was too much air going in or something like that.
You're seriously going all out eh? This kind of frankensteining will have its own problems. I don't recommend it purely as a convenience statement saja. The VDO ECU will automatically adapt to its presets so even if you do compensate here compensate there, it'll be a matter of time you'll need to redo everything again because the ECU would've adapted. Unless you opt for standalone ECU - then sure. Frankenstein all the way
N/A Proton Brudder
May 28, 2018
26
24
wouldn't that be half blocked by the head inlet that is not
sorry Iszo , i was mistaken. i misheard my dad told me it was a 2001 model. but its actually a 2000 one. so yeah. just fried wiring harness but 18 y/0 original MMC
Ah that makes more sense. So if it's a MMC then you can't be using the Satria VDO TB. Why bother seriously? Work on the internal mods, the TB is more than enough to handle the power levels you have now.
N/A Proton Brudder
May 28, 2018
26
24
stilll tho..... what abut the using the 1.5 block on the stock 1.3 mitsu ecu. can something still be done to supplement the mapping while i look for the VDO ecu and do a full conversion ? my dad told me he knows a mech that could probably kacau the mmc ecu a bit to compensate just for the moment. this is just temporary. will this actually work out ?will the engine starve out before i can even shift to the next gear ?
*urgent question* : also can an AFPR on high fuel pressure setting help prevent the engine leaning out ?
sanekit
Dec 9, 2015
1,616
157
didnt u just said your engine is MMC? i'm trying to understand the whole thing again, so u got 1.5 vdo engine that u wanna swap with your 1.3 mmc but u dont have the wiring? if the 1.5 block u have now is from a MMC, just swap in, then go find emanage or similar piggyback to compensate. MMC can use piggyback. VDO i dont think can.
I don't understand what is going on anymore. You have a 1.3 MMC Wira. You want to put in a 1.5 VDO block? Why la? If you're going to do this change the whole engine, wiring and all. It'll be so much cheaper in the long run.
Sigh.. Unichip can la dude.
after i read many post, i still cant decided what security system need to be install in my car, targeting now
1. cobra (can pay installment :P)
2. captor
3. clliford (duno where can get it in KL/Selangor).
to me it seems that all these 3 system are same, tracking, alarm, cut off engine etc. i know all these system can cost up to RM2.5k but as long as can protect my car it think its reasonble. can some one give me some advise ??
