Low Idling RPM.
mosesmk
165
32
Selangor
Dear All
My inspira suffer low idling rpm when car totally stop and in gear (D/R). 1st mechanic say it cause by my bad engine mounting. His right, engine mounting already in bad shape. change it, yet not really solve it. Idle still around 7++ and lower is 500 when idle in gear. Just need some opinion because they saying few thing could lead it.
1-Clean the throttle body- just spray the butterfly. Will totally dismantle TB soon for service.
2- Spark plug.
3-Vacuum leak.
Does anyone got this kind of problem?
You pretty much covered all 3 suspects. I don't know how it works for Inspira, but after you replace and check those things consider resetting the ECU either with the Proton diagnostic tool (and clear errors) or try unplugging the battery overnight
Why would the mounting increase idling? To what I know, bad mounting gives you vibration.....
mosesmk
165
32
Selangor
Take him round the back of the building and shoot him[/QUOTE
will try done those 3 thing 1st.
mosesmk
165
32
Selangor
no idea. when he start my car, engine shock a bit and he say engine mounting faulty and lead to low idling. last time with my manual ride, bad mounting cause bad vibration when speeding.
Yup, mounting to absorb vibration. Damaged mount cannot do that so there will be greater vibration, not low idling....
sanekit
Dec 9, 2015
1,616
157
ECU reset with a handheld obd device will fix it. need to go back to the place that u did the remap so that your current map doesnt get wiped out.
mosesmk
165
32
Selangor
Ok. Thanks. i will ask the mapping guy either he could reset it or not.
My current Evo with Tomei Titanium Expreme Ti. But I think the sound too loud until I cant withstand it anymore.
So I have few suggestion from friend to modify it to made it more quiet. But I not sure which one the best or the most quiet way. I hope any Sifu here could suggest me or provide some idea to me.
In my mind I have 2 option to choose:
1. Change the mid pipe with Center...
