Waja 1.8 Cobra immobiliser box location
Guys,
Can anyone point to me the location of the Cobra immobilizer box in the Waja 1.8?
My immo is dead / no power so now car cannot start.
Really appreciate your help here.
Thanks
ixeo
4,788
3,080
KL, Malaysia
Sure its the immobiliser and not the Renault acting up? hahaha, I can only imagine your pain.
hahaha....u ar...
so far other parts have earned my trust.
this happened b4 but it corrected itself.now still dead until today.immo fuse is ok.today will check with multimeter at fusebox to.
ixeo
4,788
3,080
KL, Malaysia
Did you try calling Proton? Or Cobra? If cobra is still in business.
I haven't tried that. Checked Cobra website and I think I go to them first.
From my exp Proton tech wont reveal their 'trade secret' that easy. Unless u guys have good friend there whom can assist me.
Last night I test using multimeter both the fusebox in the engine compartment and the one under the dashboard.
For the one under the dash, some got 12V supply but some does not got 12V supply. This is when the key is not ON. The alarm fuse got no power. However, when I press the alarm button at the remote, the car can lock and unlock itself.
In the engine compartment, its totally 0V....is this normal?
Could be the multimeter as I took few minutes to get the meter to read 0V when there is no signal.
BTW I've run through the manual and discover that the immobilizer got no fuse.
Havent got the time to test further as my hero already start to 'assist' me after 10 minutes.
When I check the immobilizer touch point, there is 5V at the middle point, no signal at the outer circle. This means there is power going there right?
Yes. Waja has a known issue with the crank sensor right? Also the cobra module is in the ECU itself I think. You can't bypass it without the proprietary cable that only PESC and cobra have. You might be better off contacting PESC
Nightstalker1993
267
130
Subang Jaya
His is 1.8, which is the Renault engine. I have 0 ideas about the Renault engine lol
Just finished rechecking the area under the dashboard and Izso could be true that the immo is built in as the touch key wiring goes into the wiring harness heading to the engine and most probably the ecu.
Crank sensor...why i didnt think of that.will search for my spare old unit and try.
I wanted to go to P1 but now budget is very tight with Raya coming,slowly buying things for house,change new workplace.
Still and engine just what u had under your hood minus the moody electronics.
Come to think about it...not to bad really as my asian car is running european engine which is well known with the electrical headache. I read a thread in zth a member is 'owning' a european car with jap engine and the engine+wiring is giving him problem...i mentioned 'owning' as he had never properly 'driving' the car.....heheheh
parakey
1,367
226
Who's that? Why does it sound so familiar?
KNN :thefinger:
yes I know
Hello guys.. Jus wondering whether its makes sense to do an engine swap to an old Fd2 to give it a new lease of life for daily and weekend ride once in a while.
A K24 swap with FD2R gearbox...on hondata, Tein coilvers with ultra racing front tower strut bar and rear sway bar. Bushings replaced and refurbished. Not gonna do those full conversion stuff though...not an R will always never be a FD2R. But jus enough to have some fun once in awhile.
Thanks. Cheers
