Twin turbo a 4cylinder engine (1big and 1 small turbine)
ixeo
4,788
3,080
KL, Malaysia
nehh, tuning small turbo cars are really pretty easy. And the tuning headache I imagine would be tuning the boost control strategy and such, fuel and ignition should be as per standard tuning strategy. But yeah, K3VET, with a TD04 upgrade should be pretty nice to drive already though of course your boost threshold will be at a higher RPM now meaning your boost will come in later
come tune my car for me :D . most "tuners" i speak to just tune boost to either on or off using a manual boost controller. there's no linearity to it. and most stuff like e-manage can't control boost anyway.
the cheapest piggy back with a boost map is AEM FIC 8. and the standalone stuff just gets better and expensive-er.
Nightstalker1993
267
130
Subang Jaya
What car do you drive? Many modern standalone these days support boost by gear, mine even supports boost by TPS lol. I actually never tuned a piggyback before though.
ixeo
4,788
3,080
KL, Malaysia
Don't drive a car, my boat is small displacement with a small turbo - peak boost at 2.2k rpm give or take. So yes, it needs to be mapped to TPS and by gear, else it won't be truly linear.
Not really, entry level like the Haltech Sprint 500 doesn't have a boost control map. Instead people use the generic output and set it to the pwm/load map, but that's open loop. I had it, sold it.
AEM FIC8 is pretty advanced -- for a piggyback, can control boost better than the Sprint 500. But alas, i drive a boat, so no point having an advanced standalone.
sweelt
Nov 6, 2016
2,306
248
drive boat dy...
still keep the sampan ? lol...
ixeo
4,788
3,080
KL, Malaysia
drive boat dy...
Boat = sampan = jukong
Diff language only ma. Hahaha. Wanna sell the sampan but feel a bit sayang.
The mods all add up costs as much as the car.
Nightstalker1993
267
130
Subang Jaya
Wow that sounds really interesting! Reminds me of those videos circulating of Thai boaters plonking 2JZ and RB25 in their sampans. Crazy! What engine you're running though? I'm guessing a marine specific engine? And what ECU are you using now? Tuning on water gonna be scary though, laptop kena water gg, unless got money but Panasonic ToughBook haha. And no, car ke, boat ke, aeroplane ke, as long as it has a 4 stroke internal combustion engine, it can definitely benefit from a well tuned standalone. Plus these days there are quite a number of standalones that are water, or at least, weather sealed, so should be no issues with salt water.
15,390
Don't take him literally. It's still a car. Just a washy suspension car hence the boat reference.
ixeo
4,788
3,080
KL, Malaysia
Washy is an understatement. Imagine driving the myvi in your household, full throttle exiting a corner, and imagine twice the power.
7,514
Hi all,
Nothing to do try to do some research online but seem a bit blur here.
Let say if we have K3VETT with 1 ori IHI RHF4 turbine for pickup and another with bigger size for end power, what will be the advantage and disadvantages ya..
or we change to one IHI RHF3 and another one bigger..
Thinking of this since if small turbine no end power and big turbine will lag..
Any know please share ya:rock:
look into subaru legacy twin turbo setup...1big 1small
not easy to install/fabricate and certainly not easy to tune also
ixeo
4,788
3,080
KL, Malaysia
ixeo
4,788
3,080
KL, Malaysia
The latest Miata is specifically tuned with body roll to improve mechanical grip....
Tuned body roll != rolling like a boat.
You ever been in a boat? Cause boat's roll around in the waves based on, well, the waves, you have no control over it.
Nightstalker1993
267
130
Subang Jaya
Well, speedboat pretty stable :laugh:
What I meant by tuned body roll means it has quite a decent amount of body roll and is done on purpose to improve mechanical grip
ixeo
4,788
3,080
KL, Malaysia
I am not sure if its done on purpose for the sampan (have to ask the engineers), but i can tell you there's no grip whatsoever from the roll, and no control.
Kevinho
94
Puchong
Thanks, I try my best to keep it simple, and that image really does help understanding the system greatly.
Also can watch this video, the explanation on the video is superb.
VGT and Twin scroll is nothing new, both pretty much have the same goal which is to expand the turbo's efficiency range. But still out of reach of the mainstream production cars yet due to most probably the high cost for a VGT turbo designed to withstand the heat of a petrol engine, and also the complicated control strategies required to operate the VGT mechanism. If you can't wait, you can get a Porsche :laugh: Also, the more moving part, the more chance of problems. I've seen the VGT vanes of a VGT turbo get stuck before so that's another thing to ponder as well.
Twin scroll turbos works by dividing the exhaust pulses, introducing the scavenging effect in a way and reduces interference between the pulses thus improving the engine as well as the turbocharger's efficiency. Since twin scroll turbos work by dividing exhaust pulses, the manifold design is of utmost importance and for a common 4 cyl, cyl 1 and 4 will be paired to 1 scroll while cyl 2 and 3 will be paired to the other scroll. If you install a single external wastegate on the system by combining both scrolls, you pretty much negate the benefits of a twin scroll as mixing between the cylinder pulses can then occur since you had basically combined the scrolls. A proper wastegate system on a twin scroll setup would require two wastegates. On a stock Evo 4+ turbo for example, there is actually 2 wastegate flappers operated by a common actuator so the gas really does stay divided all the way until after the turbo.
For more reading material on twin scroll turbos, can read a few links here
http://www.bmwblog.com/2010/01/02/twin-scroll-turbo-system-design-explained/
http://dsportmag.com/the-tech/twin-scroll-vs-single-scroll-turbo-test-the-great-divide/
https://www.rx7club.com/single-turb...s-single-scroll-vs-twin-scroll-turbos-903210/
so really, if possible, get a twin scroll turbo :laugh:
No it is really completely different. Twin charging as in 2 identical sized turbos, main purpose is to reduce turbo lag by reducing inertial mass, but still suffers from choking up top. but even that seems to be phasing out now with more efficient turbochargers being introduced. Those people with RB and JZ engines which came with twin turbos are converting to single turbos and getting very good gains.
Compound charge on the other hand, as the video I attached describe, is really like running 2 seperate turbos, one for the low end and one for up top, vastly increasing your powerband. It's slightly different than staged turbo on certain production car where there are actually flaps or valves blocking/rerouting the gas flow while compound charge really is just suck air through this turbo and push air through the other turbo :laugh:
Teach us your ways Senpai !
A Post Every 5 Mins
Hey everyone, i need some help over here and expert( you guys) advice. I was thinking of getting a second hand sports car as my daily drive around the city and long distance travel like "balik kampung".
provide me some advice please, in-terms of maintenance, spare parts, fuel consumption and anything that related to it.
My budget is about RM60K - RM80K
These are the car of my choice, but maybe you guys can suggest another car.
Nissan 350Z
Mazda RX8
BMW 330ci E46
Honda...
