Since fits both cars, wonder why they produce 2 models? Usually manufacturers will try to reduce parts production....lolYes, you need to compress the spring to detach the absorber mounting. Btw, you can opt for alza's mounting (bearing mounting) instead of rubber type mounting.
Benefit:
1. Durable than rubber type (myvi ori is suck).
2. Improve handling.
3. it's plug & play (cucuk dan main).
cons:
1. Higher ride height.
Alza top mount makes the suspension a bit stifferSince fits both cars, wonder why they produce 2 models? Usually manufacturers will try to reduce parts production....lol
I've no idea and the ori rubber mounting just get loosen feeling after like half year of driving or 10-15k kms clocked.Since fits both cars, wonder why they produce 2 models? Usually manufacturers will try to reduce parts production....lol
I feel the car height is higher than before as easier for me to come out from the car.Alza top mount makes the suspension a bit stiffer
Looks like the Alza ones are much better......lolI feel the car height is higher than before as easier for me to come out from the car.
Hmm, maybe we use firm better than stiff as I did not feel it's stiff but more firm and stable.
Yeap, it's the original absorbers.The original absorbers? If yes, then you need to compress the springs....
Thanks for the reply man.Yes, you need to compress the spring to detach the absorber mounting. Btw, you can opt for alza's mounting (bearing mounting) instead of rubber type mounting.
Benefit:
cons:
You need to jack up the car to remove the suspension. The top mount is lock down by a nut on top or do you mean the mount have torn apart?Yeap, it's the original absorbers.
Is it possible to do it with the car not jacked up ? I somehow think that the absorber mounting is gonna shoot out when I unscrew the absorber mounting without the car on jackstands
I saw a guy posted in his blog, he didn't use spring compressors, he unscrew the absorber mounting, slowly jack up the car and the strut slowly comes out. After he use another jack to jack the lower arm to put the new absorber mounting into place since the spring compressor was not there with them. It's in baikisendiri blog but I think now the blog was removed, couldn't find it.You need to jack up the car to remove the suspension. The top mount is lock down by a nut on top or do you mean the mount have torn apart?
Wah.. that's a crazy insane amount of work to remove the top mounts. You can do that but why?I saw a guy posted in his blog, he didn't use spring compressors, he unscrew the absorber mounting, slowly jack up the car and the strut slowly comes out. After he use another jack to jack the lower arm to put the new absorber mounting into place since the spring compressor was not there with them. It's in baikisendiri blog but I think now the blog was removed, couldn't find it.
I haven't tried doing it yet. This is just what I read from the blog. Any sifus here can confirm ?
No spring compressor loh....lolWah.. that's a crazy insane amount of work to remove the top mounts. You can do that but why?
I think I'm gonna do that man since I don't have spring compressors.No spring compressor loh....lol
Good Luck, as not much space for you to work with....I think I'm gonna do that man since I don't have spring compressors.
Mechanic also wanna charge me 120 labour charge to replace absorber mounting
