Proton Inspira Additional GB Cooler.
sanekit
Dec 9, 2015
1,616
157
Dear All
Need some advice regarding this issue. Planing to add a GB cooler to my trammy without discrad the original one. Setup should be as attachment.
shouldn't be a problem. u just need to check which hose is the send hose and which is return hose. easiest way is the remove the hose and start the car and see which hose push out the atf. another way is during cold start, just start the engine and leave it for a while and then touch the hose. the hot hose should be the send hose and the cold one is the return hose.
plug the send hose to the radiator. from the radiator, connect a hose to the cooler and then connect the other end of the cooler to your gb return hose. :driver:
ixeo
4,788
3,080
KL, Malaysia
Is there really a need? Inspira already have a GB cooler that Lancers didn't have.
Also, the way the coolers are installed are contradictory to popular mechanics. Flow is front bottom to top of the cooler. I'd set it up so that gravity assists with the flow
ixeo
4,788
3,080
KL, Malaysia
Isn't it closed loop with a pump moving the fluid? how is it different with gravity assisting?
mosesmk
165
32
Selangor
Mean you done installation from top to bottom? inlet top outlet bottom?
mosesmk
165
32
Selangor
how many liters does the CVT oil should be used? manual say 7l++. but SC quote me 5 liter only.
I don't have a Inspira. My ex-Sylphy I DIY installed a CVT cooler and I routed the inlet on top and outlet at the bottom.
Depends on what you wanna do. If just drain and top up it's about 3-4 litres. If remove oil pan, change filter and all - then 5-7L total
One of the most harrowing experience for any car driver is to walk to your parked car, only to find an empty lot where your car used to be. One of your first thoughts must be, “I parked my car here, right? … Right?” Then it quickly dawns on you that your car has been stolen.
A private car is stolen every 24 minutes in Malaysia and that the chance of recovery is a mere 10% on average. Furthermore, 55% of car theft in Malaysia is by hot-wiring (that is, the thieves break into your car...
