Radiator Fan
biao
348
24
perak / ipoh
Hi SIfu,
i plan to change my Radiator Fan. so ask all sifu, normally is change Original or OEM (High Speed Fan) ?
biao
348
24
perak / ipoh
to me better get the aftermarket hi speed fan unless u getting a new genuine mitsu fan.
how much for New Genuine Mitsu Fan?
i search on the market for the High Speed Fan price range RM150 - 250, depends on brands.
ixeo
4,788
3,080
KL, Malaysia
Original, or half cut of original.
Aftermarket fans not as powerful as original/oem. OEM may not be as reliable as original. Radiator fans play an important role. Or, upgrade the motor to a bigger one from another sibling, e.g. Inspira to Evo X.
Original will more expensive than After market High Speed fan?
A good aftermarket fan is about RM300 to RM400. And I mean a good brand, not some imitation brand fan. Original mitsu fan is about RM200 give or take.
High speed is always a good idea but all a matter of budget.
biao
348
24
perak / ipoh
any recommend brands for the High Speed Fan?
Honestly - I don't know the brands these days. I've never used AVS so I can't comment. But you need to ask other Airtrek members for their feedback. Like 4gbanger sifu
biao
348
24
perak / ipoh
Your aftermarket fan not same shape as your original? If that is the case, need to mod installation and maybe wiring too.
the shape ofcos not that same but the fan size can be same. ya maybe the bolt position need to modified.
ixeo
4,788
3,080
KL, Malaysia
Do i need to change the spring to adjust the front high low so called adjustable suspension ?
Its on a Kenari with a 2.8kg spring (on pervious owner) and now put into my kenari it was too low til it hit my fender and bumper was gliding thru bump.
so i went back to titan and ask them to make the front higher, titan boss mr.richard say have to put in a spacer in the spring and adjust it higher.... he say that is the most fastest and cheapest way. (but not safe lar, i think!)
another way ...
