Lower arm bush
kurt_629
872
54
johor
Hello,
Wanna ask if anyone had successfully change their lower arm bush to those better grade like nylon, pu etc
To my understanding, the best grade of lower arm, 555.
Cost around rm180 per pc.
It's kinda wasteful and costly, to change the lower arm just because of the faulty bush.
ixeo
4,788
3,080
KL, Malaysia
Superpro.
Yes usually its the bush that wears out @ lower arm. I've went through 3 sets in my current 10 year old car (not a Perdana). I've already bought Superpro but haven't had the time to put it in. Maybe after the current set koyak.
kurt_629
872
54
johor
Superpro.
Mind sharing how much you spend for them?
Complete set?
Is the size/dimension the same for all bushes?
ixeo
4,788
3,080
KL, Malaysia
Complete set?
Full set, about RM400 or so, bought from Australia -- friend hand carry back for me. Yes its a plug and play solution specific for the car.
For your application, I think you can contact local Super Pro distributor.
kurt_629
872
54
johor
Hey, Rm400 is much affordable.
Do you happen to have the part number? I can order from Australia.
How many pieces does it consist?
The last time I check with local superpro, was told it at least cost rm3k and above.
LittleWhiteWagon
1,656
187
P.J
You can google up Lan Engineering in Ampang, they do custom PU bushes as well as drift house in USJ1.
Pricing depends on the diameter of the bushings. :biggrin:
kurt_629
872
54
johor
Yeah. Tried but he's not answering to calls nor messages.
I know he does it.. but...
I'm located in johor. .
g4i8y0t
1,216
330
683
Kedah
This is off topic, but I would like to share this anyway. When changing a lower arm bush (or any suspension bush), make sure the car is on the ground before tightening the bolts. If you can't do this, jack up the lower arm before tightening the bolts. Most of the time the foreman just want to quickly finish his job and skip this step. This is to avoid 'twisting' the bush more than it's normal range of travel and make it wear prematurely. I learned this the hard way, had to frequently replace the lower arm bushes of my civic almost every year. :banghead:
kurt_629
872
54
johor
Actually Im very keen to know more from ixeo..
Rm400 is very attractive.
Mind sharing some pictures of the bush, part number if any??
hmmmm..... but I don't have that problem. I remember mechanic tighten when car still on the jack. Used for many years.......:smokin:
KenDiriwan
1,283
225
kendiriwan.multiply.com
I won't justify between custom and SuperPro. It's a matter of your budget and choice.
Had mine done at LKH Automotive Engineering ampang. Delivered the arm at 11am, ready for collection same day 5pm.
Initially only to do bush but they did it to smaller one as well, bahh.
Cost < RM250
Coordinate :
LKH Automotive Engineering Work
kurt_629
872
54
johor
Cost < RM250
Coordinate :
You mind doing me a favour, help me to ask if the shop just sell the bush alone? Front n rear, complete
I can order and have it ship to johor.
I can do the replacement and installation at johor.
All perdana owners will thank you for this. ..
Cost < RM250
Coordinate :
Probably they afraid if change the larger one the small ones will fail.....:biggrin:
drummydrew
471
was it SP Auto Tuning that you got the price from? can try them if haven't gotten to them. im also looking into bushings and need options :biggrin:
Subject: FW: Message from Plus Highway
Dear ALL.
Attached hereunder message forwarded by PLUS HIGHWAY for your attention
Hazrin
Jika kereta-kereta ini menghampiri anda, cuba elakkan dengan melarikan
diri ke tempat selamat, sebaik-baiknya ke Balai Polis Berhampiran.
ISWARA BIRU
No. Pendaftaran
WFK 6929
WHN 8719
BWB 9325
BEB 8734
BEB 8320
BEB 8323
PROTON WIRA
No. Pendaftaran
WKT 5371
Kenderaan-kenderaan terbabit adalah kenderaan yang digunakan oleh...
