Different between VDO & MMC in wira
wsonny
467
14
5,018
Ampang
Bro,
what is the different in VDO & MMC in wira 4G series? and how can i spot what ECU i'm using now in my wira 1.3 injection
Bro,
vdo use siemens vdo ecu (which the name vdo came from)
-different throttle body special to vdo model only
-use map sensor
-use crank sensor
-distributorless type ignition
mmc use mmc ecu
-similar to other 4g series throttle body type
-use maf sensor
-no crank sensor
-use distributor type ignition (or cam sensor)
Reactions: Ehab abdallah
wsonny
467
14
5,018
Ampang
which mean MMC more better then VDO, and much more space for upgrading as it similar wit 4G series...
RENESIS VIII
7,063
950
Ipoh
Just check these areas that is circled. MMC is different in these areas and also some other less noticeable areas.
Bro. RENESIS showing that you need to have your engine washed.......hhahahhahah
RENESIS VIII
7,063
950
Ipoh
In this picture, it looks ok but I think it still needs more cleaning especially near the block area. A lot of engine oil residue. Difficult to clean that.
sweelt
Nov 6, 2016
2,306
248
MMC got trade in value. kedai potong still want, i think.
my wira 2002 VDO engine, they not even want to smell it. :sleep:
Hi there guys
last year i have played around with the 4age in stock form... tried to install a gotech ecu.... on which was ok but setting the timing was problem maybe will get it right this year when i go back on holidays....
but now i want to go over the n/a field after i have bought the rx7 fd i love turbo all of a sudden..
now getting to the point..
first i just want to get the car up and running on low boost like 5-6 psi
1. i have the ecu.
2. i have a few turbos already...
