Most are removed. Nowadays windscreen would not be removed. Putting back is a problem, may leak also. Car too old difficult to take out. Gum dried, rubber brittle.....lolif can, trims, badges, rubber, cover, even windscreen need to be removed for the whole car respray....baru cantek...
Is it true, bro fazidk?
For new cars for both front n rear windscreen x remove...in fact because of d additional costs most old car owners oso x wanna remove unless of coz got rust..in short it's up to d owner..Sounds scary to dismantle almost everything for a re-spray, especially for a new car.
Sent from my SM-N9208 using Tapatalk
Why your new car already want to respray?......lolSounds scary to dismantle almost everything for a re-spray, especially for a new car.
If u willing to spend then of coz..strip it bare inside out like how d Americans do it..but remember bro they mostly do it in house meaning they have d expertise n d equipments to do it themselves...here x such thing everything has to be sub..so get ready for d cost to go sky higheerk.... rust under the windscreen.... any way of somehow spraying these areas without actually removing the screen?.... the no 1 thing i want to fight off is rust.... if there's rust i want to kill it if there's no rust, i dont want it to come!
bro, I don't think your car is that old until rust formed the the windscreen corner area.eerk.... rust under the windscreen.... any way of somehow spraying these areas without actually removing the screen?.... the no 1 thing i want to fight off is rust.... if there's rust i want to kill it if there's no rust, i dont want it to come!
The only place I could find rust on my VR was at the windscreen. I DIY took out the metal cover, scratch out the rust, sand down with sandpaper then filled it with epoxy steel. After dry, clip the metal cover back. Did not remove the glass of course.....loleerk.... rust under the windscreen.... any way of somehow spraying these areas without actually removing the screen?.... the no 1 thing i want to fight off is rust.... if there's rust i want to kill it if there's no rust, i dont want it to come!
I wanted to get red color initially, but red color need to wait for 6 to 8 months to built. I didn't want to wait. Was considering wrapping also, but still hesitating because need to dismantle also.Why your new car already want to respray?......lol
Rust go many issues one. For the windscreen I suspect is from outside, so sanding it down and protecting it from outside should last a while. However like door panel and joints, those rust are from inside and when the bubble of rust pops out, sanding that down and painting over it will last a short while only as the rust is coming from inside.....:rolleyes:bro vr2turbo should make a mini tutorial how to DIY minor rust treatment for a car.
Oh! in that case since your car is so new, I suggest you find one that have oven facilities to dry the paint.....I wanted to get red color initially, but red color need to wait for 6 to 8 months to built. I didn't want to wait. Was considering wrapping also, but still hesitating because need to dismantle also.
