need help wit my starter??
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
dear sifuses,
my problem is, the starter wont stop working even when the engine already starts, even more surprisingly it's still working when I turned off the key. thought it was the relay problem, changed wit my horn relay still problem persist, spent a bit more & use a new 1 just making sure & stil same problem, it even burnt my jumper coz starter wont stop, luckily nothing severe happened, if the other car engine wasn't running bet it'll drain the batt 2. any thoughts @ this prob??:banghead::banghead:
Ignition switch problem or wiring. Current still going to starter from battery direct.
twistedichc
2,930
255
683
Ampang Point
thx for the reply, ask mech he said sumthing inside starter maybe stuck, it moves out when starting & supposed to come back in when engine starts. if it is so, if the car edi start which wire should I disconnect but engine should still run. thx for your enlightenment sifuses:adore:
ken yeang
6,617
1,327
maybe the solenoid got problem, thus keeping the starter motor running instead of being disengaged.
Yup, the power actually goes to the solenoid first that powers the starter. Chinese mechanic call it the mouse. This is attached to the side of the starter.....
The smaller unit is the solenoid
twistedichc
2,930
255
683
Ampang Point
if I'm not wrong, both starter & solenoid needs the batt power to runs rite, should I detach both supply or either way is possible or just take out the relay, coz I want to make sure that I can ride my car to w/shop to change the starter without having other problems on the way.
try swap the relay first
You another one did not read...haha TS mentioned he switch the relay already
---------- Post added at 11:38 PM ---------- 6 hour anti-bump limit - Previous post was at 11:32 PM ----------
Not sure if yours is the same but basically is like this. The ignition switch trigger the power through the relay to the solenoid. This will trigger the solenoid to take power from the battery directly and trigger the starter. Here....
forgot read it realier but still want to write that :rofl:
try ketuk2 the solenoid with spanner/plier or any metal that can reach there a bit to see it the stuck came from solenoid or switch at steering in the first place...
See bro. twist result after checking......:driver:
i'm driving proton wira 1.5 auto now i planing to transpalnt my stock enjin which enjin is suggested ,4g91 ,4g92 mivec ,6a10 and wat is the price to total transplant include JPJ rear brake modification bla bla bla.... so i hope sifu sifu out there can help me thanks
