4G13 cam
synail
259
19
3,018
hi guys
im planning to get myself a 270 in 275 ex camshaft
and adj cam pulley for my 4g13 motor
Am i gonna have trouble idling with the a/c switched on?
4gbanger
1,958
386
1,683
Johor/ShahAlam
im no sifus.. but using 270 degree above sure will affect the idling.. normally they uses ficd to increase the idling level for aircond.. discuss with ur mechanic first..
Cam too high, difficult to drive too. 1.3L cannot extract much from that power plant....:smokin:
hi guys
270 in 275 ex, that's a pretty mild cam la. The a/c might be affected a little but otherwise you'll be fine la.
synail
259
19
3,018
Thanks all....really appreciate it
Can i really feel the performance gain after installing
this kind of cam?
If it is mild cam, don't expect too much from it, right?
this kind of cam?
You'll feel a difference for only a certain range, depending on how you set the cam angle. Whether it's significant or not depends on your car.
Spend so much don't get the significant difference then want to cry already.....:bawling:
hi guys.. relatively new to car accessories and mods....
need help in a couple of simple Q..... hope u guys can help out..
1. whats a "spark" as in "pivot spark" use for ?
2. heard changing crank pulley can increse the car hp n torque rite.. any guys here done it ? ....
3. read in some mag tat says..... changing cam pulley also can increse power....(i only heard ppl changing crank and not cam pulley) .....any 1 of u guys changed r cam pulley ?
main Q = if any 1 change crank and cam...
