Downsizing proton inspira 1.8E MT tyres, make the
johnstoney86
Mar 16, 2015
31
Sarawak
It is possible to downsizing the tyres of Proton Inspira 1.8 MT from 205/60/R16 to 195/65/R15?
The 205/60/R16 tyres are very expensive and I want to keep the car maintenance fee low. I need to know pros and cons of my action. My driving speed usually will be 80~100KM/H.
(Example Michelin195/65R15 91V with online price sale on RM 275 each, but the 205/60R16 92V cost me RM 400 each)
Thank for all usefull information.
I choice the tyre spec, becuase it only 0.74% diameter different compare to the original tyres spec. Second, most 195/65/R15 tyres have load index and speed index that suitable for the proton inspira model
ken yeang
6,617
1,327
Should be fine physically.
TS could gain very-slight pick-up, and maybe slight improvement of fuel consumption.
think its ok..
less than 5% difference overall..
be cautious on the tyre load rating though...
Is actually 2.74% smaller only
---------- Post added at 10:02 PM ---------- 6 hour anti-bump limit - Previous post was at 09:57 PM ----------
205/60R16 to 195/65R15 is 2.74% smaller. Better size will be 205/65R15 which is only 0.75% smaller means almost same diameter.
I read in another topic, you do go off road, therefore 205/65R15 will be better. Using 195/65R15 you will be slightly lower, and tyre width narrower therefore traction will be less.
205/65 is slightly more expensive than 195/65 but still cheaper than 205/60R16
---------- Post added at 10:03 PM ---------- 6 hour anti-bump limit - Previous post was at 10:02 PM ----------
FC better can be because smaller diameter over reading by 2.74%......hhahhahaha:biggrin:
Same brand and type but different size? I heard before tyres like RE002 is more expensive for 195/55/R15 compared to 195/50/R15...
I say, 195/50R15 is smaller than 195/55R15. Even PS3 195/55 is more expensive.
As suggested by bro VR2, better use 205/65/15.
As for the pros & cons of this downsizing:
Pros:
- cheaper tires
- more comfortable
- might slightly improve your fuel consumption if you use lighter rims.
Cons:
- handling/steering response is more dull.
- less high speed stability, will feel more floating.
- might not look as nice (but this is subjective).
Similar threads   Forum
Wheel And Tyre
  Similar Threads
Wheel And Tyre
Hi i'm not sure about whether this fact is really an actual fact or is just a plain myth.
and i'm not sure whether a not i'm suppose to post this up over here or this is a repeated thread a not. because i try searching it and i can't seem to find any thread regarding this issue.
ok so here goes, some of the people say's that when you have just purchase a new car, you shouldn't have drive above 80km/h(or less) before the first service for the car so that the owner can preserve the...
