i said compared to others ma. i dun have money oso rcs, titan, all customs for swift go beyond 2.8k.Wah...bro swifterific...rm1700 is cheap for you...
Buy for me oso lah.
Neo83,
1300 for hi lo soft hard,bodyshift unit is considered as cheap.
the only thing that worries me is the 8k front spring rate.
Yup, 100% Malaysian made. The founder was former head/chief engineer of ride & handling dept. at Proton. As far as I know, yes much better than GAB or Performax brand. From what I've read in the forums, even Titan suspension users also had switched to Ftuned after spending countless hours tuning their set up at Titan's..Is also another Malaysian Made products right? Better than GAB & Performax?
gunnerzz; Neo83 said:what do u mean Gunnerzz..
i dont know about spring rate.. :hmmmm:
8k spring is to hard or what..
Most of their adjustable uses an inverted monotube setup, which is far superior than conventional twin tube designs that many other brand use. An equivelant Tein MonoFlex adjustable would cost you RM 5-6k IINM.Yup, 100% Malaysian made. The founder was former head/chief engineer of ride & handling dept. at Proton. As far as I know, yes much better than GAB or Performax brand. From what I've read in the forums, even Titan suspension users also had switched to Ftuned after spending countless hours tuning their set up at Titan's..
Oh Performax tak ada adjustables. I mean is locally made.Performax got adjustable now?
Gab have been under bad reputation for having leak in less than a month now.they no longer have factory in japan right?
RCS not for ordinary people due to the price. Is reputable and heard lot of good things about it. Is the price that whether one can afford it.a friend vouched for RCS. well made, good quality customs. that's what he said la.
Ftuned roughly price range is around where bro? Almost same as HWL or cost a bit more? I'm guessing at least RM2k+.GAB japan bankrupted many years. Current GAB are local made which made their reputation worst than many other local brand.
For budget below 2K, i could only direct you to HWL.
Decent one would be BC.
Most recommended by me would be FTuned.
TEIN very the stiff wor ppl sayif got extra budget I suggest halfcut TEIN's.
HWL better. xDi think mostly suggest HWL..
tq all of u..
actually i prefer GAB..
but now maybe i go to HWL..
i find new product from HWL..
U will like it la...our sifu Taikor TitanRev also using it and his saga handles damn well.saya MUSTI pilih..
walaweiii..U will like it la...our sifu Taikor TitanRev also using it and his saga handles damn well.
that is FAKE or what?:hmmmm:
i knew form here..
HWL Adjustable Suspension
>>> 15 Step Soft Hard
>>> Hi Lo Bodyshift
>>> Spring Rate 8k Front / 4k Rear
>>> 1 Year Warranty
promotion Price - Rm13xx only
( Installation Available )
Only For Proton Wira.Waja.Gen2.Persona.Satria
Rs Racing Motorsports
i vouch for Fawster. very good workmanship and friendly staff. i went for their alignment service and setting coilovers only btw. wait my current coilover kong first only try their custom coiloversHi guys. Anybody has experienced Fawster Motorsports set up?
You change tyres already confused, now add suspension become more confused......lolOh Performax tak ada adjustables. I mean is locally made.
But no matter the spring rate, once u go adjustables it will not be comfortable right?
HWL better. xD
They have different spec, ranged from 2k-3k+. Depending on your requirement, hilo / hilo + soft hard, body shift, pillow ball. Lower end spec are none inverted shock and high spec are inverted monotube.Ftuned roughly price range is around where bro? Almost same as HWL or cost a bit more? I'm guessing at least RM2k+.
owh..thats ori HWL new packaging...black body with yellow-ish orange spring...
its cheap already and what most current market price....
i got mine almost 5years ago same price but the basic without soft/hard and without bodyshift.... (older version chrome body+blue spring)
u want to use on satria neo right?? select 5k front spring and 3k rear spring.....or atleast 6k front and 4k rear....should be pretty good for daily driven car
that is info i got from FTuned..They have different spec, ranged from 2k-3k+. Depending on your requirement, hilo / hilo + soft hard, body shift, pillow ball. Lower end spec are none inverted shock and high spec are inverted monotube.
I guess you can say that way for adjustable, but tuning is essential. Did test ride on my friends car FTuned surprisingly comfortable that any adjustable i ever experienced ?
owh..
can i choose any spring rate or is it come with package set sir..
---------- Post added at 02:48 PM ---------- 6 hour anti-bump limit - Previous post was at 02:44 PM ----------
Satria neo rm1950 hi lo monotube, rm2200 hilo inverted monotube/monotube, hi lo soft hard inverted monotube/monotube rm2700
*pillow ball top mount add rm450
*race-comp spec add rm300
noted ^pomen_GTR^choosing spring range depend on shop/seller
but most didnt allow....but good news is hwl,gab adjustable spring is cheap..as low as rm70/pcs (used) and if not mistaken HWL brand new spring just rm150 (if want pure new item)
Still okay, cuz not aiming on adjustables that soon yet but most probably have to replace absorbers by this year also..You change tyres already confused, now add suspension become more confused......lol
Okay, comfortable word got my attentionThey have different spec, ranged from 2k-3k+. Depending on your requirement, hilo / hilo + soft hard, body shift, pillow ball. Lower end spec are none inverted shock and high spec are inverted monotube.
Rode along Farouk demonstrate how his product could perform, i could tell you comfort isn't far from OEM. In fact i liked it more because stock suspension always give me wavy sort. Despite all corner he whacked like a real race i could still enjoy it pretty much, heck my seat wasn't even bucket one.Okay, comfortable word got my attention
Will check it out. Thanks man!
