Bridgestone RE002 or Toyo T1R Feedback
yewly1990
156
28
Hello there, I need some feedback of Bridgestone RE002 and Toyo T1R, my size are 205/50/16
Grip, dry usage, wet usage, noise level, comfort etc...
I use it for daily driving, both price are about the same, currently I`m using Thunderer from thailand.
Base on feedback, RE-002 better in the dry, T1-R better aquaplaning Resistance. Comfort should go to T1-R as quite soft sidewall
yewly1990
156
28
So, RE-002 are better for dry usage, T1R are better in wet usage and much comfort.
The tyre I using same tread with T1R, really nice in wet usage, and good grip too, but quite noisy, and sidewall hard like rock, quite bumpy.
I used the T1-R before and needed much more air pressure to corner proper because of the soft sidewall. My size was 215/45R17.
Probably your car is light and using 45 series aspect ratio will be bumpy for you...
issuzark
861
66
IIRC T1R has quite bad wet grip though, from the reviews that I saw. That's what stopped me from getting the T1R in the first place.
dkny
211
10
Dry - RE002
Wet - T1R
Comfort - T1R
Quiet - almost same
Price - RE002 higher
Re002 - Thai / Indo
T1R - Japan
---------- Post added at 09:41 PM ---------- 6 hour anti-bump limit - Previous post was at 09:40 PM ----------
Re002 even worse
yewly1990
156
28
Dry - RE002
Wet - T1R
Comfort - T1R
Quiet - almost same
Re002 - Thai / Indo
T1R - Japan
Re002 even worse
Hmm... actually I dun really drive fast when rainy day... but izzit any different between indo made and thai made Re002??
---------- Post added at 10:16 PM ---------- 6 hour anti-bump limit - Previous post was at 10:09 PM ----------
I prefer 50 tyres, I tried conti mc5 with 205/45/17, felt bumpy too, Rather stick with 205/50/16.
issuzark
861
66
Dry - RE002
Wet - T1R
Comfort - T1R
Quiet - almost same
Re002 - Thai / Indo
T1R - Japan
Re002 even worse
That sounds really bad. Have yet to encounter anything yet. :slug:
Am running on a pair on Indo ones now. So far, so good. But bumpy and noisy.
dkny
211
10
Indo or Thai made same quality, still Bridgestone, Japan QC.
The only bad thing is, u buying Japan Price tyre, but made from Thai/Indo.
yewly1990
156
28
Hmmm, so actually just choose between comfort... hmm.... Too bad i dun have the bucks for R1R, or else I will go for R1R
I've heard that Myvi can convert fully passo dashboard with the meters working with only abit of wiring modification.
But is it possible to put Passo Dashboard + passo meter with yrv wiring?
Really scared to buy the dashboard before knowing does it fits or not. Advice from sifu or anyone whos ever done it. Thanks
reason for changing dashboard : very badly scratched.. :bawling:
