Evo 7 differs after change of radiator coolant
satria81
813
18
5,018
PETALING JAYA
Hi All,
My car was running perfectly fine until I changed my radiator coolant 2 days ago.
I drained the entire coolant and replaced with 04 litres of Mitsubishi coolant and now the issue is as below:
my temperature gauge is showing only 1/4 temperature ( so low ) when driving & when on idle the gauge is showing less than 1/2 which was the normal or usual temperature prior to change of coolant, regardless during drive or when idling.
Anyone knows why is the temp now at 1/4 during drive. All thoughts would be greatly appreciated .
pangyau
1,153
302
1,683
Malaysia
satria81,
Probably something clogged on the hoses or need to change the thermostat.
You may re-flushing the radiator again...to see to outcome.
satria81
813
18
5,018
PETALING JAYA
good morning pangyau,
if the hoses are clogged, the temperature would be high rite .. ?
mine is showing very low temp.
Dayline668
1,810
492
1,683
Check thermostat is it jam open.
peterj
1,321
258
1,683
Kuching
water temp sensor, usually located around thermostat housing:nurse:
From far, when I saw this green reflected on the ceiling, I knew it was something special. Verde Ithaca. I was familiar with the colour; this was a colour option from the Lamborghini house, and a rare colour on Malaysian roads. Gallardo? Murcielago? I gotta admit, I was a little excited to find out what it was... the last time I'd seen this shade was a couple of months back on a Gallardo Spider...
