oic..I know Evo's 5x114.3 can.
Probably cheaper than Exora since get from chop shop.
b'coz 5lug is more easy to find offset >38..why?????
i think so..no experience doing it at neo but planning to do this also..
if changing to exora bearing can pnp i think its alot easier..
me too..Nowadays more cars comes in 5 lugs that is why rims manufacturer also follow......
any risk if i drill DansEterna??drill the holes easier.....look for lan engineering @ mudah.my
I remember its PnP. Any mechanic also can do. Just need to source the hub.oic..
PnP or need some mod stupidcar?
---------- Post added at 08:09 AM ---------- 6 hour anti-bump limit - Previous post was at 08:04 AM ----------
thanks stupidcar..I remember its PnP. Any mechanic also can do. Just need to source the hub.
depends on the person that drills the hole, so far lan engineering has experience on converting 4-5lugs without any issues.any risk if i drill DansEterna??
thanks DanzEterna..depends on the person that drills the hole, so far lan engineering has experience on converting 4-5lugs without any issues.
alternatively u could get the 4-5lug converter, works as a spacer as well.
evo4 also 4 lug rite..not 5..if want to mod lug only drill hole maybe the most cost saving way..
but if want to upgrade to larger rotor & maybe twin pot along the way maybe can try evo 4 onward brake..cost abit high also have to think about brake pad & rotor replacement part after that..
Drill the rims?drill the holes easier.....look for lan engineering @ mudah.my
evo 4 using 5 already..evo4 also 4 lug rite..not 5..
