My car air cond ..not blown cool air,after installing the power amp,player ..
rawther
71
508
penang
I wonder why .. My car is using yrv engine ...that day I already fill up with the gas ..but just last for 2days ..when I switch on the a/c I can hear zzzzz ..sound come out from a/c vent ...before that I'do heard squicking noise nowadays ..mostly after rain ..
Can somebody help me ?
:D
:D
So from your story should not be the fitting of the amp problem, but basically you should have a leak in the air con system? Since you need to refill gas means you have a leak. Trace it first before another refill as two days means leak is pretty bad...
dekaiser
94
33
installing power AMP could mess up your wiring system if not done properly...but when your aircond is faulty...mostly it is due to your aircond system...cooling coil leaking,compressor koyak,drier container tersumbat... etc refer to aircond specialist for further rectification...
Depends on the installers. If amp normally they take power direct from battery but if HU then they tap from wiring....
Hi. I would like to ask for some help. I would like to know what type of engine oil is good to use for a v6 engine which has done around 98 000km for around 5 years?
Also, how much is it usually to pump the air cond air and gear oil?
Would really appreciate all the sifus help as i'm a very young guy who jst started driving. Thx alots ! :)
