Engine jerking when coming to a stop - what's the problem?
Apache91120
97
2
508
Klang
Experiencing this problem lately. Sent to Proton SC to check but they say "everything is OK" but the problem still exist. What could it be?
15,390
Describe the problem in detail like how you replicate the problem and stuff. For all you know you might have warped brake discs. How is the jerking? Describe a bit more or take a video.
Apache91120
97
2
508
Klang
It will happen once or twice a day. If it is brake problem then it might occurs every time I stop but it should be checked too. It feels like the engine is going to die off but so far it didn't perhaps because I will change the gear to Neutral.
Apache91120
97
2
508
Klang
Yes! I think that's the culprit. It's called "Purge control valve" and the "Canister assy" but the service center could not find any fault because perhaps they didn't check or they just don't know
30,002
Since you mention putting in neutral is okay, probably your idle speed is too low, so when in gear the engine is vibrating in low idle....:smokin:
Apache91120
97
2
508
Klang
I have been recommended to a workshop in Taman Petaling Utama, P.J. Called the owner yesterday and he said to bring the car for checking.
---------- Post added at 09:59 AM ---------- 6 hour anti-bump limit - Previous post was at 09:57 AM ----------
Or it could be a clogged TB?
What is this & where is this thing located?
30,002
TB aka Throttle Body, attached onto inlet manifold leading to air filter
Apache91120
97
2
508
Klang
Give it up. Its normal. It feels like choking then it jerks.
But actually, yeah, it is normal. Mine 2012 Persona Auto as well.
Air cond compressor kicked in is worse.
No, it is surely not normal. When something is not right, it should be checked & rectified. Normal principle in everything. :driver:
juz now see my fren turbine.
At the housing only got TD04. But me 1 got L, mean td04L.
what diff btw have the L n dun have the L ?
thanks ya.. :embaressed_smile:
