Saga FLX issue (help me)
driftkingII
2,123
278
5,183
Bandar Utama
Anyone Saga FLX owners here?
I want to clarify a few things before I go to service in Proton.
Car cannot start, I remembered when I learn from JPJ, if car cannot start it is either battery or air.
So the instructor did a demo he disable the air and the car cannot start.
I have changed my battery and so far ok.
Later this problem still come back, cannot start. So what I did was I removed the air filter and pat it to remove the dust and then my car can start. So i suspected it is the air filter issue. So if I cannot start I will do this 1st and it works everytime.
*sometimes this also happens during after service, already 3 times.
Today I called the Proton service, they said no air filter issue and it is luck that the car can start after doing that.
so guys i need to know? is this the air filter or not?
Please advise
*car still under warranty till this November, was thinking to kill the warranty after replacing the power window.
driftkingII
2,123
278
5,183
Bandar Utama
check your air flow sensor. does your car crank?
not a crank sound but the sound like car no battery, btw i already replaced the battery.
I read in some forums they said immobilizer.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
When you turn ur key to ignition can you hear the fuel pump sound? the car can crank or the starter can't crank at all?
driftkingII
2,123
278
5,183
Bandar Utama
Sorry for the info about crank but yes my car crank, this cannot start issue does not happen most of the time.
How to know air flow sensor and also Fuel pump sound?
Scary thing is it happens always after servicing at Proton service...
have u fit any electrical device such as ICE, aftermarket alarm system etc etc???
i suspect something was draining your battery....
or ask SC to check if the car original grounding was tied properly or not
TitanRev
Mar 3, 2005
8,180
3,678
The fuel pump sound appear when you turn ur key to ignition. You stand beside ur driver door, turn the key to ignition but not start then listen if you can hear a Eeeee sound for a while as the fuel pump pressurized the fuel line. Then it will automatically stop. Try to find a quiet place to do it but the fuel pump sound on saga is quite loud. Also when you crank that time is the cranking sound consistent or during cranking sometimes fast sometimes slow.
driftkingII
2,123
278
5,183
Bandar Utama
No bro, this car i do not want to put all those fancy stuff or modifications. This car i want to keep it stock.
as i said earlier this happens sometime n also after service at proton SC
driftkingII
2,123
278
5,183
Bandar Utama
Went to SC today.
Proton found the root cause, it is the ECU. They told me ECU upgrade will be ready soon n they will inform me when it is ready.
^pomen_GTR^ u nearly got it right and thanx !!!
bro Titan, Fuel Pump working fine, i tested it
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Went to SC today.
really? then I must tell my collegues as well... seems lots of my FLX frends suffers the same issue as well
EvolutionZ
5,000 RPM
5,027
1,448
its good that the SC can troubleshoot this. ECU issue? something new. lets hope it work well after the re-programming.
normally your case, if got mileage...its either
- fuel pump faulty
- air flow sensor loose connection
- immobilizer..
but from what i read there...none of the above..then lets share once the SC can settle yr problem.
driftkingII
2,123
278
5,183
Bandar Utama
- fuel pump faulty
- immobilizer..
No news from PSC.
but it is a very common issue as well when i googled here.
Saga Flx(a) Engine Can't Start - Autoworld Forum
also i read here, somehow stupidcar issue is something like mine
http://www.zerotohundred.com/newforums/proton/440695-1-6-campro-persona-hard-to-start.html
Anyway guys, i just killed my warranty "car battery died on Merdeka night,"
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
bro... one of my friend suffers the same issue... and his solution is very simple...
yank out the immobilizer... the car can start with out any issue.... been 1 year plus plus
but then, your warranty is void la
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Same as this right?
https://www.youtube.com/watch?v=AVU-xV4bks8
been getting this almost on a daily basis now... but as per video, i just
  1. Close the door and lock it via remote
  2. wait 10 seconds
  3. unlock the car, start it and it cranks like nothing happened
there is this satria i could get a hold of.. which has been abandoned for bout 3~4 years but i dont know if it'll be worth it.
its got preety much no interior, there seems to be a piggyback ecu (e-mange) and the engine seems to be a 1.8 gsr turbo(not entirely sure.. could be a hybrid:hmmmm:)
but what i want to know from all the sifus out there is what do u need to change/fix/whatever to get it back in good running condition? and around how long would it take? how much would it set me...
