Persona Owners Thread
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I think is to make the mounting flex less right?
:o Purpose? Sound dampening?
It's the DIY method of making a solid engine mount. If you've ever seen those PU solid engine mounts they don't allow the engine to move around as much theoretically transferring all the power directly to the drivetrain. It's the 'softer' alternative to the solid steel engine mount since PU allows for some very minor flexing.
jackocc123
Apr 5, 2012
7
any one here using adjustable ??
Just want to ask what Spring rate suite for persona , for stable when corner+ comfort.
A. Front 6K + Rear 4K
B. Front 4K + Rear 4K
C. Others
DIY for that then will need stronger materials other then window sealants....:biggrin:
Hai guys i need help and suggestion on my Perdana v6 twin Turbo 6a12tt regarding changing timing belt and engine mounting.I went two workshop so far,they're said use the same Perdana v6 timing belt,is that true? Regarding engine mounting Which workshop is trusted around klang valley._also im gonna change belting,water pump,spark plug,down parts lower arm,upper arm etc.Thanks in advance guys.
