Choosing Lowering Coil Springs for Inspira
WPQ800
1,445
92
1,648
Hello all, im using inspira 2.0, changed my wheels (17j x 8j x off40 x 235/45 csc3) and now wanna lower down my car... im having issues just like any other users as to what brand to choose and why....sorry my bad.... i was actually referring to vogtland, H&R, gab, tanabe, Eibach, etc.... and it would be great if we can conduct review session on these coils and how they behave on malaysian road as a daily driven ride..... i can volunteer but we need a team effort here....
first we need a running team sbb kalau aku buat sorang lagi 2 bulan la jawabnye hahaha.... volunteer from inspira owner yg dah pakai vogtland, h&r, tanabe, proride and eibach, or any other type of mass produced over-the-shelf coil springs for inspira/lancer to come forward.... janji damper std... baru even ground.... (although we cannot control factors such as engine weight, rim size, tyre height, etc, etc....)
aku prepare schedule & venue, cari photographer & videographer (atau ada yg nak volunteer?), we need a "post review writer/narrator and web person to start uploading to links to this forum, youtube, FB, and make hype..... i can also try getting hypertune to cover the review too in their mags.... we can have the owner himself go through a slalom and braking and short modulated circuit.... we can try to somehow simulate normal malaysian roads too for comfort test.... let say we get together and talk this out bros? this could get serious if we pull the right strings.... anyone volunteering?:stupido2:
1. I volunteer my self as the "control car"....std damper with std coils with 17' rims.... - Ash, Shah Alam, 0193963693:evil:
2. ?
3. ?
Sylver
37
18
1,508
Subang Jaya
Hi bro, nice thing you're trying to do here. i am a 1.8L manual inspira owner. also switched to 17inch rims but my tires are 225/50/R17 instead of 45. results will vary slightly just with tires alone. but my ride is lowered with eibach sportline coilovers but OEM dampers. also have ultra racing struts and anti roll bars.
all these factors will tweak the car's handling, so the only way for you to get an apple to apple comparison is to uninstall all non-OEM parts in each owner. :biggrin:
WPQ800
1,445
92
1,648
yup i must agree there are factor that are not easy to control but what the heck..... hahaha lets meet up bro..... spread the words... are u in?:listen:
bird9799
41
2
1,508
Hi there,
Just to share my experiences when I'm visiting R3 center. I checked with them on R3 coil spring compare with std spring different 30mm. It has the same comfort, better handling and lowered than original spring. If you have 18' rim, from tire to fender is around 3 finger height. The guy told me that currently is out of stock. I wonder why the sales is so good bcoz on the road I hardly see lowered inspira. R3 guy said lot of lancer owner also install R3 spring because of the price factor and it has what most Malaysian wants. (Comfort and handling).
Anybody try out Tein coil spring? the price is slightly higher than R3 spring and cheaper than eibach. I want to know the height and comfort level after installing Tein coil spring.
xxixx
163
2
Hi there,
Seriously on the lancer part? haha
gabantromen
114
2
Miri, Sarawak
Heard tein s-tech is also good.there's also proride, which is kinda cheap as well..
WPQ800
1,445
92
1,648
Actually the teins are better if you are going for a bit more performance. Between the three, actually the proride performs the best cos its pretty stiff....
If compare between eibach, tein and proride, the lowest would be tein,then proride and tallest is eibach...
by spring rating, the hardest would be proride, then tein then only eibach.... depending on what you want as the ultimatum... but if u want to be able to configure and customise the only solution would be fully adjustables..... HL/SF....:adore:
amrancharger
779
96
the cons with tein s-tech is dat it might lower the car more than expected.
wif malaysian road...a lowered ride will create hassle for the driver.
radhie
535
51
[/URL][/IMG]
Using sapura proride,handling feels much better than stock
It looks like Germany's autobahn system is safe from a potential increase of speed-limited areas, for now at least. As posted on numerous occasions, environmentalists, the European Union and even citizens of Germany have called for the adaptation of 80 mph (130 km/h) limits in the currently ungoverned sections. However, today the Chancellor of Germany, Angela Merkel, publicly rejected a proposal aimed at reducing automotive...
