fuel smell during boost kicking!
4gbanger
1,958
386
1,683
Johor/ShahAlam
Dear guys, have anyone here in this forum facing the same problem as mine?
during boosting, there's a fuel smell in the cabin. i try to seek some mechanic friend, and found nothing
leaks in the engine bay. weird but dangerous as it kept me feeling dizzy...
Pls advise anyone... TQ
bLACKjAC
122
41
I had the same experience before. Initially I asked my mechanic to check the fuel regulator, hose, injectors, at the end I still have the same problem. Few month later, I did overhauled the engine, and the problem gone. I guess the smell may come out from engine
4gbanger
1,958
386
1,683
Johor/ShahAlam
are u using fuel regulator? need to re-calibrate it yr fuel too rich.
thanks bro.. will ask my mech frens to calibrate the pressure..
---------- Post added at 02:19 PM ---------- 6 hour anti-bump limit - Previous post was at 02:17 PM ----------
i think ur rite.. since there's no leaking at engine bay.. if it was because of fuel to rich, the smell would have came out from exhaust.. correct me if i'm wrong..
DanzEterna
15,910
3,371
www.primeperdanaclub.com
in my case, everytime i turned a sharp corner i will smell fuel....checked the engine parts but unable to trace...
so 1 fine day when i was pumping petrol in shell, the bangla suddenly pointed below my car...i was like wtf? he told me to bend down,
i saw fuel leaking from the hose connecting to the tank.
got it change the next day after that no fuel smell.
4gbanger
1,958
386
1,683
Johor/ShahAlam
haha... yup ur rite bro. sometimes the problem is not major problem at all. but still don't play2 with petrol smell..
stutzedward
3,416
561
I got the petrol smell when I start my engine in the morning or when the rev is high. At first I ignored it and later, it became stronger. When I pop up the hood, to my surprise the fuel regulator was leaking. It's like squirting out fuel, not dripping. So I tighten the clamp and problem resolved.
3 months later, same smell came out. I check the fuel regulator again, the bugger was again squirting fuel. So I removed everything and retighten again. Hope no more 3rd time!
kaninbu
669
104
lol....squirting fuel ya....
sorry i saw wrongly,i tot foul smell.check ur fuel pump n is located under rear seat.btw is ur fc getting worse?
Sifu's ,
Need help ASAP ,
My engine timing will drop dramastically when slow down , when the time we want to brake and when want to take a turn . This problem causing the car to jerk when braking and some times the engine will shutdown by it self when the aircond is ON . When the engine is in idle mode it is not smooth . :mad: :mad: :mad:
I have already checked the timing and did some fine tuning . Still occours . Now i feel unsafe to drive my car as the engine intermintently shut...
