Project MU brake products: are they very good?
30,002
Gahh.. I guess that's the difference between a big expensive car vs my Wira. I found and bought the Bendix Metal King Titinium for my rears yesterday for RM80.
Last time I bought the BMK Titanium for my front was RM100 only.....few years back. Anyway the Trestor from same manufacturer, I got for RM120 last year....:driver:
jerrysiow
407
146
Seremban
Haha bro, 6UE5t upgrading his setup at sunway kakimotor. The price of the stuffs also need to include heavy rental as well. I never change spare parts at sunway area due to mostly alot of parts are overpice. Last time quote me Osram nightbreaker H4 need RM160 and I was walk away and found same at S'ban area just only cost me RM90 included installation.
30,002
Okay, noted. Osram in SEA Park Spare part shop also around RM90 only....:driver:
Well the pads I did not buy from them cause they don't have them. The MKT I bought from Kent Goh and the Type NS pads from N1 since they're the only one I can find to have that one ready stock (others nly have the basic Bestop and the higher more expensive B-Spec). From Kakimotor I only bought the rotor and brake hose. I've asked around many places for those items and the rotors & brake hose are the best price I could get after about 2 weeks of asking around. Other places they ask 1300 for the rotors not including install! Brake hose roughly about the same prices everywhere so the difference of rm200 for the rotor price made me go there. They also did not charge me additional labor for the pads replacement since I bought the rotor & brake hose there, so I think not that bad.
---------- Post added at 11:16 AM ---------- 6 hour anti-bump limit - Previous post was at 11:07 AM ----------
Hmm the thing is the sucky std Toyota rear pads for my car is already like rm200! So rm160 is already cheaper. I've aksed some other sellers too and roughly gave me about the same price, just maybe rm10 difference.
30,002
Yup, OEM pads are lousy and are more expensive. My colleague's Accord I think he mention OE pads around RM400 so he also fitted Project MU pads....:biggrin:
Yeap, Rm400 is the same price as my Project Mu NS already!
jerrysiow
407
146
Seremban
Haha, you are a hunter 6UE5t. Can get cheaper price around sunway + it's kakimotor. Wa, you almost burned 2k on the brake system, so satisfied with your new brake system?
Not almost, it's already OVER rm2K! :banghead:
So far yeah, satisfied. Will update later once I can test it with more force/hard braking.
15,390
Slotted and cross drilled rotors just allow you to brake without worry about fading (not as worried, not completely don't have fade), awesome pads let you brake harder but paired with slotted rotors your pads will wear out faster. With the steel braided hoses your pedal pressure should be very linear and controllable.
If you're talking about braking harder and faster - probably yes for the harder but not necessarily faster. Your car has ABS and EBD so you'll still probably stop the same distance but you'll be able stop the car at higher speeds in comparison.
I think. :hmmmm:
30,002
Over RM2k, not good also must be good......hahahahahha:rofl:
---------- Post added at 03:46 PM ---------- 6 hour anti-bump limit - Previous post was at 03:43 PM ----------
I think. :hmmmm:
Slotted will minimized brake fade a lot. I think what he likes most is the initial bite which is much better now....:biggrin:
Hahaha yeah, with that much spent, it has to give a good improvement!
Anyway I'm happy with the improvement especially the initial bite, it gives a lot more confidence. I think it should allow me to brake faster because now I can achieve more braking power with less pedal travel, while previously I have to press much deeper to get meaningful braking force. I think you're right though that once the brakes lock up, the ABS should take over and from then on the distance could be about the same. But maybe now is much easier to lock up due to better initial bite.
30,002
With better bite, it should stop faster. The idea is not to lock up unless emergency......:driver:
15,390
It's a lot harder to trigger the ABS than what most people think. I've tried a dozen times on my Myvi and have only ever successfully done it 1 time in a controlled environment. The other times were real emergency situations (about 4 times.. :biggrin:)
Anyway, I wish I had that kinda dough to blow on a car. I want bigger calipers.
Oh hey, 6uest - you should consider swapping out your brake oil (flush) with DOT5.1 (assuming your car isn't on DOT5) especially from those reputable brands like Ferodo and Motul. To me the brake oil made a helluva difference when I was *driving aggressively* down Genting (caveat - not racing). Even with the same brake pads for some reason the oil helped reduce the super spongy pedal feel as a result of overheating. Not that you'll be cooking your brakes often but hey, overkill is better than regretting.
jerrysiow
407
146
Seremban
6UE5t, your rotor is slotted 1 right? Is it noisier than previous setup when you apply brake?
Hmm to trigger ABS you just need to really stomp on the pedal as in during emergency braking. I've successfully done it several times on several different cars. In the wet it's very easy to trigger it though.
No, I just use regular dot 4 for now. Maybe later will try when comes time to reflush it again. Thx for the suggestion.
So far still no noticable noise yet when applying the brake. Just when I release it from stop, then got just a bit 'ngek' sound which previously not heard, but that's all.
jerrysiow
407
146
Seremban
So far still no noticable noise yet when applying the brake. Just when I release it from stop, then got just a bit 'ngek' sound which previously not heard, but that's all.[/QUOTE]
Ic. Last time i using slotted type, when doing braking above 80km/h, there will have some noisy "woooong wooong wooong". It disappeared below 60km/h. Yup, i also got that 'ngek" sound when fully stop.
30,002
Like bro. 6UE5t mentioned have to stomp hard on the brake all at one go then only ABS will activate, or your Myvi ones not sensitive enough......:biggrin:
---------- Post added at 04:14 PM ---------- 6 hour anti-bump limit - Previous post was at 04:12 PM ----------
Is Dot 5.1 not Dot 5 which is silicone base, just in case....:driver:
Myvi with a K3-VET engine swapped in.
The engine was opened apart.
1. Engine block checked, tested the deck for flatness
2. Cylinder head checked, tested for flatness
3. New gasket
4. New water pump
5. New thermostat
6. New radiator cap
7. Radiator flushed and cleaned external of the car, pressure tested
8. Radiator fan working properly, added additional Panasonic 12" auxiliary fan in front
9. Coolant using distilled water + Toyota long life coolant 70/30 mixture
10. There's a...
