Buy & Sell your RX-7 and RX-8 here.
Looking for an FD, preferably with cooling mods done up as I planned to go track. I've owned an RX8 6MT before, and spent a lot of efforts to solve the water temp issue until I could do continuous lapping without worry of overheating.
Any FD owners track their FD? what's your cooling mods, how many lap can u go and what's your max temp?
Thanks
Rrotary bro.. Theres a red fd a few posts above is selling at a reasonable price .. If not you can also consider mine! :3
Rx7 fd3s 1992 for sell.
Custom viper bodykits.
Ori twin turbo.
C-West headlight.
Selling 88k.
Pls call 0167100520.
Why do you two want to buy an FC3S? Most of the FCs that you can find nowadays are pretty banged up and in need of massive parts replacements.
guess they don care about the interior,, and as for engine can easily buy a half cut and swapped in.. and then wa la ready for drift.. or is my guess wrong?
An FC is not the best car for drifting. Easier to use a Nissan Silvia or Cefiro (A31). Or one of the older models like KE70s and the like.
The FC's setup is for grip and it is a grand touring type of car. If you want to race on a circuit, some adjustments to the suspension setup and it makes for a very serious race car (just not as good as an FD). But drift isn't a strong point.
the cost has taken over the choices of car..
i think the r e blog apparently has died..
FD RX7 was the best rotary sports car. Came RX8 but performance was a serious let down. All in all, rotaries are also unreliable compared to piston engines. Maintenance cost is high and needs rebuilding very frequently if pushed hard. So...that's why RE dies...
Hi Adam,
Sorry for being such a stick in the mud. But seriously, passion is easily killed when you have to fork out time and money to fix all the problems of a 20 plus year old car that has been trashed (or neglected) by previous owners. I wish I had my own workshop.
Not everyone can afford it. Can you imagine driving your car for a few days in a month after which it has to spend the rest of the month in the shop? It is not pleasant.
I've easily spent twice the original price I paid to fix up my FC from the axle frames to replacing the transmission to rebuilding a blown engine. And it still has more work to be done to internals, body work and suspension.
If the purpose is to drift. There are better cars to drift in that are cheaper to buy and run. Even an FD is a better idea.
---------- Post added at 06:42 PM ---------- 6 hour anti-bump limit - Previous post was at 06:28 PM ----------
Rotaries are no more unreliable than pistons. If anything, they are more sensitive to maintenance - or the lack of maintenance. I.e. they are more fragile... really really fragile.
Piston engines don't need to be rebuilt - which is essentially an "overhaul" for pistons. Rotaries must be broken down at least at 100,000 KMs. Also, our weather and traffic jams are pretty crap for hot running rotaries. People do not know this and this is the primary cause of problems for rotaries.
If you compare an old cast iron piston engine to a rotary, the piston is going to win because it can overheat and seize up without too much problem - it will re-start when it cools down. Rotaries can't - they warp and melt internally.
But if you compare a modern alloy piston engine to a rotary, the difference is not too big. Alloy piston engine heads will warp and become unusable when they over-heat. And that's what a rotary is - it is an all alloy engine block - aluminium, iron-alloy, carbon/ceramics and cast iron.
There is one white non-turbo FC drop-top model in PJ area that has run nearly 30 years without issue.
what i hate the most is,,, the car died in somewhere then waits for hours for the tow driver to come.. who need to shake off first.. ha ha..
looking for RX7 FD3S for project with broken/damage engine or without engine.
must be with registration card (road legal)
PM me.
Thanks
A thread every 60 seconds
