which got better response?? lighten crank pulley or adjustable cam pulley?
mcdull
Sep 17, 2012
17
503
I using 4g93 dohc. change lighten crank pulley better performance or adjustable cam pulley?? need 4g93 sifu guide for technical modification engine.
mcdull
17
503
Thx sky.. considering jasma l.c.pulley.. wats ur opinion.. wat car model n engine u using? mind to share info??
cam pulley any day :adore:
yup i stay at mines...but i rarely do for other ppl's car...usually for my own private motorsports job only :adore:
there's a lot of 4g93 tuner here in zth...surely u can buy parts+install with reasonable workmanship easily.. :driver:
D7zul
2,697
848
Shah Alam
cheaper things 1st :biggrin:
coz our mods is limited to our money, right? :wink:
mcdull
17
503
Thx for all suggestion.. pomen gtr u mistakenn le.. not ask u change d parts, ask u minum when got free time lerr... anyway i'll oways be in cheras n pj area. Welcome to msg me 012-9444984.
I wouldn't bother with the cam pulley because ultimately your cam shafts are still stock. Stock most of the time works best with '0' settings (stock). Advancing or retarding stock cam shafts is like choosing what paint to spray your car. Not going to make any difference in performance but sure looks nice.
Crank pulley is a good investment but don't undersize by too much. Overly undersize will make you want to swap back to original if your car is a street car.
quicksilver7
313
66
I read some article from Dinan BMW that said, undersized pulleys would affect the accesories (water pump, air con, wtv is attached to the crank pulley) at idling speeds.
i agree that there's not much effect on SOHC....
but on DOHC car....they made a whole lot of different...
its like u have 2-3sets of stock camshaft from different engine spec. to play....
especially when u change the overlapping duration of both camshaft... :adore:
p/s:however stock setting still the best balance between fc and performance.... :driver:
D7zul
2,697
848
Shah Alam
undersize pulley will spin ur accessories slower than original
meaning,
1. ur air-cond won't be as cool as b4
2. ur alternator will charge ur battery slower
3. water pump slower
4. power steering not very sure what will happen..
so, think b4 u undersize..
if same size, it's ok by me coz i'm using it :biggrin:
yup..under size pulley only meant for racing to reduce drag from alternator and power steering pump...(also if got aircond surely aircond drag was less but compressor not enough speed=ac not cold) :biggrin:
if there any oversize pulley i'd choose that...
mADmAN
1,840
547
agree with this... no point changing cam pulleys if ur still running on stock cams.. coz the best is usually at 0
even avantech's 6xxwhp VTEC Turbo monster is running stock cam pulleys with the stock Type R cams..
get same size lightened crank pulley....u get improvement without worrying about accesories being affected. mytheology seems to be a popular choice
Dear Sifus,
Need your advice on the matter above. Recently when I shift the mmt gearbox to D the light was ok then a few seconds later the D light is blinking. What is the reason? After that I pull over at the road shoulder and engagse to N but the D light is still blinking.
Also, when I try to engage the E and S mode the selector indicator is not shown at the panel cluster.
I never experience this before.Please help... :banghead:
