Im planning to change my tire very soon. Im just too confused to pick which one of it. T1R or Directional 5? Help me please.. Thanks!
What are your priorities? If aquaplaning resistance the the T1-R will be better. It's pattern resembles the older GY F1 GS-D3 which was the best aquaplaning resistance tyres to date. However with more grooves then rubber and having good aquaplaning resistance, the dry grip suffers because of less rubber contact which is needed in dry grip.Im planning to change my tire very soon. Im just too confused to pick which one of it. T1R or Directional 5? Help me please.. Thanks!
Agree with bro. madman, the T-1R sidewall a bit soft. I have tried before, even wet grip in my VR not good. Might as well you try out the F1 D5 then....T1R has soft side walls...so cornering is a lil tak syiok.... but it does perform well enough on wet roads..
F1 D5 should be Thai Made. Thread wear not sure, should be around 280that GY made in? whats the tread wear like?
if its 280, its the same as T1r with AA traction A temp.F1 D5 should be Thai Made. Thread wear not sure, should be around 280
Federal RSR sure sticky because extreme tyres but for heavy rain use not good....hi all,
i just use Federal RSR, damm stick, dun feel ski at all whwn cornering, previously was using Hankook v12, also not bad, BUT...compare wif federal....cant fight at all....i use 205/50/15....bought at rm380....if u hav bucjet....u will not regret...
just curious, does country made makes diff in a same model tyre?if its 280, its the same as T1r with AA traction A temp.
let say the price more or less, i vote for T1r japan made.
I used before GY Asy Made in China by GY factory. Just as good as German ones.....just curious, does country made makes diff in a same model tyre?
hi all,
If you're looking to participate in the TIMETOATTACK, you get 20% offwhere to buy RSR with RM380?
please pm me...
thx bro...
the event finish d....If you're looking to participate in the TIMETOATTACK, you get 20% off
Enjoy 20% Discount off Federal 595RS-R and FZ-201 at TIMETOATTACK!
