WTA: Federal tires
csl
1,285
498
1,683
Malysia
I used to hear people say Silverstone tires got problem and always got pregnant syndrome. I didn't believe it and finally I got it and wasted the rest of 3 each (fairly new). I felt no point to keep something that will potentially kill my father in law so replaced with 4ea China brand and so far so good.
Now I wanted to buy federal 595 series. I heard people said its side wall always crack. For not being a victim again, I would ask everyone here who use Federal before, is the crack thing for real or rumor only? :confused::confused:
spirit20816
47
18
1,508
Previously used once and personally experienced the crack of 2 tyres among 4. Friends of mine all experienced the same circumstance some even noticed the crack from left side wall to right and that looks terrible. The life span of the tyres last me 1 track day and a year.
ken yeang
6,618
1,327
My previous use of silverstone brand tyres had fine line cracking at the sidewall/thread area.
But I have friends using Federal and have good feedback.
Not only local or cheaper brands, there are also bulging from Conti, Pirelli, GY and so on. Looks like depends on luck also.
Bulging/crack sometimes due to hitting pot hole or hitting the side curb which we might not know also....
csl
1,285
498
1,683
Malysia
Looks like I have to pick Nexen or something else.
carent9
252
13
Selangor
Well...
SS595 is less durable (long term) but a great tyre to be used for track days and if you want to take corners at tree hugging speed
595 Evo is much better than SS595 and is a great tyre to be used daily and value for money...
Look at the ratings of the tyres and you will understand... SS595 cannot take high loads (people) as I guess it was mainly designed for drifting.... at great $$$$
595Evo is serving me very well...
Well...
Why you mention cannot take heavy load? Size to size between different models, the load range is the same unless XL is mentioned. For example 215/45R17, load range is 87 and XL is 91
---------- Post added at 11:18 AM ---------- 6 hour anti-bump limit - Previous post was at 11:16 AM ----------
RSR is your budget is bigger...
SS595 is more suitable for drifting...
Yalor, RSR sure more $$$.....
carent9
252
13
Selangor
If you look at the ratings, then you will find tht it is lower vs. the 595Evo. It is not it cnnot take heavy load, but cannot take as heavy load. I feel it is because it was meant more for drifting purposes. :smokin:
I look at the 595Evo and 595Ss specs already. Most of the Evo made with XL load. If you look at the smaller sizes like 195/50R15 & 195/55R15 without XL mentioned the load range is the same at 82. In fact Evo for this size lose out in speed rating with V only where SS have W rating.....
carent9
252
13
Selangor
The EVOs has Z rating for a few ranges..
---------- Post added at 12:43 PM ---------- 6 hour anti-bump limit - Previous post was at 12:06 PM ----------
I am using 205/40 17 and 215/45 17s on my cars, so when i compred before i bought, 595Evo was better on the spec sheet..
nyantong
192
50
Before buying tyres, you better check the manufacturer date. Some irresponsible shops keep tyres for more than 5 years and still sell them. Best learn how to read the manufacturer date. As for Federal, I'm using Evo for 1 year. Havent seen any cracks yet.
15,390
csl : I'm using Federal Evo 595. 195/55/15
Have been on track once and it did quite well until after about the 10th lap then it started giving way much earlier than it did on the earlier laps.
Driving everyday with it in the rain and dry roads has never been a problem either. Been up Genting for a few spirited runs and very predictable and easy to handle.
It's been almost 2 years and they are starting to go bald. High thread number means it's a little harder than most tyres and very much noisier than my last tyre (Mich PP2). I actually can't stand the tyre roaring noise anymore. Imagine with 55 profile it's that bad, your lower profile it'll be worse! But mine's a Wira so it's got bad insulation to begin with.
Otherwise I can't fault the tyre. No cracks, no bulging, nothing. If I one day manage to insulate my car, I wouldn't mind using these tyres again.
What air pressure did you pump? According to one friend he got better traction with less air pressure.
Your lost of traction at the end could be due to overheat....
Hi all
Quick question. I think my oil sump need to open and service there are traces of oil dripping. Does oil sump got gasket? Or need to open and apply new sealant around it and put it back? thanks
