What is this red & black thingy?
BoxCarRacer
524
103
Johor Bahru
Guys,
I've browse through couple of Import Tuner magazine online and saw this red & black cap on Honda cars. What is it called and what is the function of it?
kayour
326
41
maybe spare pipe...or tubing...or sumting for service job
maybe la
ken yeang
6,617
1,327
since there is an empty compartment (suspect of car battery space), i think the two "plug" could be the auxilary power point, to be connected with outside power source. without on-board battery, the car would be lighter. Battery normally used for start up. Once engine started, the alternator will generate electricity. Even unplugging the car battery, the engine could still run.
just my opinion...
l2s_turbo
1,068
154
Might be the point to jump start the car..
D7zul
2,697
848
Shah Alam
1st time i see the pics, i thought it must be a battery related thingy..
coz red is for +ve & black is for -ve..
:biggrin:
BoxCarRacer
524
103
Johor Bahru
Battery remote jumper? probably and it makes sense too since the fact the its in red & black in color.
I am not sure about it but i've seen it only in Honda cars and the the placement of those tubes different from each other. One is outside while another one is in the engine bay.
D7zul
2,697
848
Shah Alam
i think it's true..
on track car, they will find a way to lighten their cars.. coz lighter car goes faster..
the purpose of a battery in a car is to start d engine.. if engines started, then there's no use of the battery..
of coz we need to charge the battery, but for track car.. CHARGE SOME WHERE ELSE LA.. :biggrin:
on track car they often lighten everything.. change mirrors to plastic, change bodyparts to carbon fiber..
it's common :wink:
rokok_sebatang
394
97
Its not only honda cars used this item..google it then u will find..most use it for jump starts when battery access is difficult esp when relocate the batt..might be la..in terms of safety i oso dunno :confused:
:smokin:
Asking all who are proficient in wiring.
car is sgti which has 2 spotlights infront. normally, then main head lights are switched on, then when press switch on the dashboard the headlights can be switched on.
However, i've change the main headlight cables and relay. now when i switch on the head lights i can't switch on the spot lights. the spot lights can only light up when i completely switch off and then switch on again.
Why is this so? is it the relay?
can i rewire the spot...
