A32 Brake Pump Status !!
Cheongxp
Selangor
Hi all,
Wish to get you expert advice how to confirm Master Brake Pump is in good condition or not ?
Recently went to Genting for twice, when return time both time brake power reduce after heat.
1st time non-stop direct back to KL, brake pad gone.
2nd time rest at Gotong Jaya for supper, then continuousb back KL, brake pad still ok.
Maybe i not well how to downhill without use so much brake force, but a32 gear box drop to 3rd gear or even 2nd gear it didn't have engine brake function like Toyota Advanza or Gen2.
So no choice need to press the brake.
My friend drive my car when back, him suspect Master Brake Pump not in good condition as pressure/torque very less.
Frankly speaking I also disapointed to A32 brake performance since i own the car.
Thinking change to Chop shop 4-pot, but worry the replacement part/performance wise after invest.
Now i think this is last point need to improve so far.
So anyone have any suggestion/advice ?
FYI I using original A32 Twin-pot ( 3.0 spec ).
If you go downhill rely on brake only is very dangerous. Unless you have very big disc and good racing pad.
Use 2nd gear, and 1st if required. I go up and down many times no problem. Hardly apply more than 30 sec brake. Use engine braking.
Try flush your brake fluid. If you want better braking power, upgrade to metallic pad but very noisy. Or upgrade to 4 pots R32 / R33 :D
Weikee,
I understood.
But i wish to confirm my Master Brake Pump condition also.
So any suggestion ?
Don't know. Do vacuum test maybe?
Funny, the JDM 3L with higher HP come only with single pot. And I find after putting the JDM master pump + my current 2 pot brake. Is much better. Now with the metallic pad it feel so much like a brake :) Feel like: Apply brake today, stop today.
But I want to have brake that: Apply brake today, stop yesterday.
Ic, I looking for Apply brake today, stop today enuf
Brake today, stop yesterday for me look like drive with Hand brake ON
Maybe 2L or 3L share same Pump spec.
Need to shop around soon.
How much cost you for JDM Pump ?
Hi all,
In order to check the brake master pump. Put the car in "D" and hold the brake pedal down. If it slowly sinks to the floor then the master pump is defective. If the Vaccum brake booster/servo is spoilt the brakes will get harder and harder to press like when the engine is off. Also you would have to check if the one way valve in the vacuum hose to the brake booster is ok or not. Also you need to check if there are any vacuum leaks in the hose which supply vacuum to the servo.
Are you mistaking brake fade with brakes no power. Sounds more like you have brake fade. In that case get better brake pads rated at higher temps. Also get a set of teflon steel braided hoses for the brakes.
Malaysia TC don't bring in Japan Original brake pad for A32 anymore. If not mistaken the one selling is local / key-value. Original usually cost RM 4xx to 6xx.
If anyone got to know where they selling let me know.
Weikee... PH Auto in Seapark do sell. But that was years ago.
I got once post compatibility of brake pad of A33 and A32 for front. The rear one still not yet change since the car came out from factory.
http://www.zerotohundred.com/newfor...ity-of-brake-pad-a32-and-a33.html#post4141046
" If the Vaccum brake booster/servo is spoilt the brakes will get harder and harder to press like when the engine is off." Bro if the brakes get harder during sudden braking, Is it due to brake booster as well?:confused:
When engine off, it sure have problem la, cause no more vacuum mah.
msybe u can check vsnli at jln ipoh..i think they have the japan set. i am running stock set up. when up genting n down. it works fine.....
did not rely entirely on the brake....got play with the gears at well when goin down hill...
Yes, there is most probably a small vacuum leak in the booster, the hose or the one way valve.
Last time when i drove a turbo car, when the engine is on boost >0, It will have no vacuum. And brake will only function if the reserved vacuum is available. Lucky enough i don't need so much braking when it go on boost.
Thos still driving turbo car give it a try, when on boost try step on brake pedal few time :) and you enjoy the no braking until you release throttle.
Not sure what car you driving. Some big cc car have a reserved vacuum tank because when engine on boost it will have no vacuum supply to the brake.
So if you have a bigger vacuum reserved just use your left leg slowly apply brake and do it few round and you notice your brake getting harder and harder to apply.
BUT PLEASE DO THIS IN EMPTY AND STRAIGHT ROAD.
I don't drive turbo any more. Used to have a rotary. Will ask my friend to try it out on his Subaru. If like that on NA car also the same theory should work. Just load the car to 0 boost and do the same. Will try that out on my civic manual easy to load to 0 boost on fifth gear and load speed.
On NA not so easy, cause when full throttle you only got few sec to play around. Usually the brake vacuum reserved can be good for few "stepping"
A thread every 60 seconds
