GutterUncensored.com Censored In Malaysia By Inbred Gov. Officials For Streamyx Users, It Is Time To Fight Back
Posted: 02 Aug 2009 07:55 PM PDT
Source:
www.GutterUncensored.com
Please Copy And Email/Post This Elsewhere.
Years of inbreeding has never produced anything good! The GutterUncensored.com was blocked or restricted in Malaysia about 5 days ago. This time instead of getting Blogger or Google to remove the site from the Internet all together, the overly controlling fascists ruling Malaysia have been knocked down off the world's censorship stage and are now resorting to block the site locally using ISPs in their country. The small fishes have return to their small pond where they can be as tyrannical as they want. The MCMC with the help of Streamyx is blocking GutterUncensored.com from the Malaysian people. But don't worry, there are several ways to get around this censorship in Malaysia (See Below). And basically end all Internet censorship in the country.
http://www.gutteruncensored.com/" is permanently blocked by the Malaysian government. There are several ways to get around it but if you do nothing it is not accessible if you are using TMNet’s DNS server. Only some Internet user who subscribe to certain private internet service provider in Malaysia can access the website freely. Those user who subscribe to "Streamyx" Internet service provider are unable to access the Gutter Uncensored site. Currently 70% user in Malaysia subscribe to Streamyx internet service provider, so a lot the blog's readers are affected.You should consider switching your ISP if you can from Streamyx to another.
The Malaysian government officials are blocking the site because some of them are now living in fear of what pictures and/or video might pop up on the blog on any giving morning. You can understand there fears right? Nearly all are stealing from the nation's treasury, most cheat on their wives, some are murders and there and a few rapist as well. They have much to be afraid of and since the the Gutter blog has no problem exposing them with pictures and video. The good thing is they don't have family trees, they have a family web so their inbred asses will only retain power for so long. The British Royal Family once ruled much of the world but years of inbreeding brought that to an end. If nothing else, the prevalent inbreeding among the ruling family of Malaysia will be there down fall.
All Malaysian base DNS server are blocking the website now. So the solution is open source DNS server and HTTP/CGI base proxy. Here are four easy ways to get around and END ALL INTERNET CENSORSHIP in Malaysia and else where for that matter:
1)
The easiest and best way to view the Gutter Uncensored is to change your DNS in TCP/IP setting (see detail instructions below) to use Open DNS IP Address. They are: 208.67.222.222 and 208.67.220.220 and then you can surf the Gutter Uncensored and any other blocked website without the need for any proxy site.
This is the easiest and best way because you only need to do it once. And then you can view GutterUncensored.com and any other blocked website for that matter.
For Windows XP users:
1.
Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
2.
Right-click the network connection that you want to configure (the one that connect you to the Internet), and then click Properties.
3.
On the General tab (for a local area connection), or the Networking tab (for all other connections), click Internet Protocol (TCP/IP) from the list, and then click the Properties button.
4.
You do not want to obtain DNS server addresses from a DHCP server, click Use the following DNS server addresses.
5.
Enter 208.67.222.222 and 208.67.220.220 then click OK.
And you are done!
For Windows Vista users:
1.
Click Start, click Control Panel, click Network and Internet, and then click Network and Sharing Center.
2.
Click Manage network connections from the list of tasks.
3.
4.
On the General tab (for a local area connection), or the Networking tab (for all other connections), click Internet Protocol (TCP/IP) or Internet Protocol version 4 (TCP/IPv4) from the list, and then click the Properties button.
5.
Select Use the following IP address.
6.
And you are done!
2)
You can still access the website easily using HideMyAss proxy website along with tens of thousand other such proxy sites.
This is the most common way to get around the Internet censorship. First you need to find a proxy site, there are over 30,000 some better than others. Use Google or Yahoo to search for "free proxy list" and chose a proxy after clicking on one of the search results. Click on it from the list of proxies and when the page open you will need to enter the blog's URL "http://www.gutteruncensored.com" in the blank field then press enter. And you are done!
Here is a short list of web proxy sites. You can search for others because there are over 30,000 more.
http://bypassanything.com/ or
https://proxyplace.net/ or
https://proxify.com/ or
http://www.hidemyass.com/ or
http://miniproxy.org or
http://ibypass.net/
3)
You can use the UltraSurf program. It is free and easy to use.
UltraSurf allows you to overcome the local censorship and blockage of the Internet. You can browse any website freely and anonymously, so as to obtain true privacy and information from the free world.
It can be found here:
http://www.ultrareach.com/
And you are done!
4)
Not sure how well this work but someone sent me this interesting tip via email:
I know recently your website has been "blocked" by some unscrupulous people. Well, they didn't block your site actually. I am still accessing your website using Streamyx without using any proxy whatsoever.
So the trick is:
1. Go to
2. You will get server not found, etc error messages.
3. Keep hitting refresh (Your browser Refresh button or F5). About 13-15 times, you will be able to view the page.
It works perfectly without using any third party proxy or change any settings.
And you are done!
Hopefully one of those methods work for you. Drop a line at
[email protected] if you have an additional suggestion.
Please, someone send a list of other website being blocked or restricted in Malaysia to
[email protected]. I only know of a few but I think there are a lot more. The least the Gutter Uncensored can do is give them additional web traffic.
http://www.facebook.com/pages/GutterUncensoredcom/71689381800
GutterUncensored.com Admin
Thank you!
