R Line Performance
Works Engineering Cam Gear
-Brand New
-Each gear is adjustable in 1 degree increments to
a maximum +/- 10 degrees
-Simpler design and being lighter than the stock
gears
-Tooth profiles matches the OEM spec exactly. The
outher cos section of the gears is black
hard-anodized, to prevent on wear and tear from
the timing belt.
-The 5-bolt locking patternis plenty secure and
use only stainless steel hardware to ensude
durability and provides a lifetime of worrry-free
adjustment
-The machining process guarantees you out gears
will not come loose when you follow the torque
specifications
-Horsepower gains can be vary widely depending on
what has been done to the vehicle and how it is
used. Gains from 5-20 Horsepower can be realized
Contact Details
Mobile : 019-2931222
Email : [email protected]
Dealing Method
COD / By Courier
-Brand New
gears
the timing belt.
adjustment
specifications
Contact Details
Dealing Method
COD / By Courier
