yung
Each Gear is adjustable in 1° increments to a maximum +/- 10°. Our engraved timing marks are accurate within 1 minute of degree! With the simpler design our gears end up being light than the stock gears they replace. Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt. We use black hard coat because of the great contrast it gives against our engraved timing marks. The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustment. Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions. Horsepower gains can vary widely depending on what has been done to the vehicle and how it is used. Gains from 5 to 20 horsepower can be realized.
call 014-6411291 to order
model
MITSUBISHI
EVO 1-8 RM245
4G92/4G93 DOCH RM235
LANCER/PROTON 4G92 SOCH RM229
LANCER/PROTON/4G13/4G15 RM229
T7.LANCER CS3/4G18 PROTON WAJA RM249
6A10/12/13 ETERNA/PERDANA V6 RM240
T7.CAMPRO/GEN2/SATRIA NEO/PERSONA/NEW SAGA RM240
HONDA
B SERIES DOHC RM239
H SERIES DOHC RM225
K SERIES DOHC RM240
NISSAN
SR20DET RM235
RB20/25/26 RM235
MAZDA MX5/BP6/BP/NB6/8 RM249
BMW 318I/E30/E36 RM249
TOYOTA
SUPRA/LEXUS GS300/2JZ RM240
4A-GE/4AGE RM245
3S-GTE MR2/CELICA/CALDINA RM245
DAIHATSU L200 12V/MIRA TURBO RM 239
model
MITSUBISHI
EVO 1-8 RM245
HONDA
B SERIES DOHC RM239
H SERIES DOHC RM225
K SERIES DOHC RM240
NISSAN
SR20DET RM235
RB20/25/26 RM235
TOYOTA
4A-GE/4AGE RM245
