wiring problem
nicteh
423
all sifu out there,
need help for my car wiring, thanks!!!
problem 1: Headlight bulb problem:
Some times cannot ON,must On n Off alternatively,around 5-6 times or more, even highlight also.
problem 2: Signal problem:
It happened only for left side, it blink abnormal (very fast),at 1st i assume is bulb burn out, but nothing wrong with the bulb. It happens sometimes also...
problem 3: Reverse sensor problem:
Sometimes there is not functioning, mean no sound when shift to reverse gear and no light also. sometimes okay...
How to solve this kind of problem? any1 know where got wiring specialist to check with?
shawnme
41
bro,
i'm having the same problem...only worse...
so how did you fix it??
and how much did it cost??
regards,
shawn
DarkAccoon
880
432
3,063
for ur headlights problem
may i ask if u installed a 100W conversion kit?
if u did, then re-check the wiring and see if any are loose
if not
then i suggest u check the connector for the bulb, see if there is any burn marks
=P
reverse sensor, i used to have that problem also, but then i threw the sensor away, cause if according to the sensor, i would have killed nearly half the population of subang residents
as for ur abnormal bulb blinking..... check ur wiring and see if there is a cross circuit
hi...i am new here erm i am driving a kembara
the engine of the kembara gets hot very fast ...is like a 15 mins drive and the thing got very very hot .....can anyone teach how to prevent it
i m changing my air filter soon...izzit good ? :(
pls gives some reply thx
i love u all
