Hello, ![Biggrin :biggrin: :biggrin:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif)
Want to let go a Proton Wira original body 1999 (C99)
Engine 4G93T GSR (INSPECTION)
Engine officially converted with GSR (25+HP)![Driver :driver: :driver:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif)
Engine good maintain.
Last modification cost estimate about 20k.
Price want to let go is RM22k.
INTERIOR
Bucket seat at front
Rear seat original recaro.
Door panel original wira c99.
Boost meter Apexi
Dashboard original Lancer (black colour)
NARDI Steering(original)
Earth kit grounding cable
Fuel pump walhbro
USB and CD player
Pivot Speedometer.
Razo gear knob.
EXTERIOR
Bodypart depan Evo 1.
Suspension adjustable HWL (F:12K , R:8K)
Sportrim RPF1 with Bridgestone Potenza Re01 tire (PCD114.3)
ENGINE SPEC.
Head port and polish
Cam retainer and valve spring JUN
Camshaft gti
Adjustable campully aerospeed
Screw head ARP
Custom intake manifold for GSR.
Banana stainless steel
Turbo tdo5 (Evo 3)
Wastegate Tial
Intercooler custom
SAMCO radiator hose
Piping fully stainless steel
Piston oversize 82mm
Crank pulley alloy
Blitz Air Filter.
Use air flow sensor from Evo 3
NGK Plug cable
NGK Iridium spark plug
Engine fully balance (flywheel+crankshaft+main pulley)
Clutch Exedy semi racing+triniti clutch plate
Lighten flywheel
Throttle body 70mm Super 90
Injector VR4
Oil catch tank Cusco
Timing belt kevlar (blue)
Fuel regulator sard original.
Management - E-Manage blue
Engine maintain using MOTUL 4100 Turbolight 10W-40
The car is very responsive and not just ordinary GSR engine.
Can view it first if interested.
The location is at Shah Alam.
Anything, can contact this number : 0192736559 or 0104645659.
The name for this car's owner is Man.
:wavey:
INTERIOR
Boost meter Apexi
Fuel pump walhbro
USB and CD player
Pivot Speedometer.
Razo gear knob.
EXTERIOR
ENGINE SPEC.
Camshaft gti
Screw head ARP
Turbo tdo5 (Evo 3)
Wastegate Tial
Intercooler custom
SAMCO radiator hose
Crank pulley alloy
Blitz Air Filter.
NGK Plug cable
Lighten flywheel
Injector VR4
:wavey:
