Which will u choose?
AkiNa VaMPiRe
Guys..wonder which engine will u choose...if u concern about fuel consumption, spare parts availability and also the maintenance fee for the engine.
4g91,4g92,4g93,4g93t,mivec or evo engine. which one will u choose?
id choose 4g63t, halfcut & aftermarket parts plenty, no need to
waste your time looking for it, easily available.
i see..but i heard alot ppl say evo parts hard to find ...=.=!
bro DanzEterna, wanted to ask..if let say wan engine that have good fuel consumption, which engine should choose?
4g63 oso good consumption... depends on how u drive...
i still can get around 400km per full tank for mixed driving....
cannot really remember le... been a while never drive my car d...
should b around 40-45lit la....
but really drive like uncle... rev max 3k shift... no boost at all....
i am assuming that u are refering to the much popular conversion and sought after chasis (CB,CD and CE) not the CK version and above.
-all engine above will give a decent fuel consumption if left stock. if power to weight ratio is not an issue, i think 4G91 would be the best.
-4G91 efi would be the best and easiest parts available to look. thru my experience from all halfcuts that i've gone thru (except east malaysia) its easy to stumble 4G91 efi spare parts. (the manual gearbox is a bit pain the ass though. quite hard to find) the hardest of them all would be 4G92 non mivec.
-maintenance wise among the n/a 4G9x series, is basically the same. turbocharged and valve lifting engine needs meticulous care. on the heat management side and engine oil side. the rest are all the same.
if u want good fc go for 6a10 1.6 v6.
but parts getting obsolete soon.
but if u ask me to choose from your list, i would go for 4g92.
but now mivec halfcut already rm10k++.
since the demand is very high.
4g93 la.... he he he he... power is there and if left stock... everything ok...
92 non mivec is pretty hard to come by.... if not then u use 4g91 with 92 block....
mivec price getting sky high... GSR oso same same... almost on par with evo price d....
u worry bout FC ah bro?
y not u go for 4g93p as advice by 93na & add on NGV.
u got both power & good FC
Hello.... I driving Proton Iswara with Mivec engine .. And already drive for the 6 years...
The fuel consumption RM 50.00 can run 240km... Full tank run almost 400km...
1.6 DOHC MIVEC....
My suggest is 4G92 or 91..
May I know you drive wat car....
