What causes brake imbalance?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
the road speed limit, or the car?
just joking la bro vr2turbo... you layan me summore will get this thread screwed out of topic hahahhaa
Follow speed limit loh....:biggrin:
heh! heh! yalor, actually the road speed limit is the insane speed.....:rofl:
especially 60kmh on trunk road....
Wonder where is Lesley? Got his brakes checked?
LesleyAprotto
Banned
1,339
287
683
Still not solved yet my brakes problem...
First I changed new rotor disc on both sides as the old discs are found to be worn unevenly...
The disc got ups and downs of slopes in the centre...
As the pads are still surprisingly thick, I didnt change it, moreover it was Bosch brand so I left it as
it was.
Was very confident it was the disc problem, however after testing it, my brakes still imbalance, became worse.
Second day went back to the workshop again...
This time I changed new brake pads...
Upon changing my mechanic pointed out that my brake pads are crooked, and bent!
Can anyone tell me why the pads are bent on one side of the brake?
Same time I do bleeding and flushed the Dot 4 brake fluid.
Hope my problem will be solved!:mad::rofl::confused::adore:
it was.
Bro. Les,
The pads follow the shape of the disc. If disc is crooked so will the pads. When reading your post I was about to ask whether you sand your pads flat before fitting to your new disc, but since now you have changed all the better.
LesleyAprotto
Banned
1,339
287
683
Bro. Les,
Finally my problem is solved!
Things that I done are...
1) Changed new rotor disc
2) Changed new brake pads
3) Brake fliud bleeding and replaced new brake fluid
4) Serviced the piston calipers, using high performace white grease.
5) Computer resetting of all 4 brake system.
Hope anyone with brake imbalance problem in future can refer to the above!
Thanks to all whom participated!:itsme::wavey::biggrin:
For what car?
If the piston, then must be rubber grease. If it is the pins then high temperature grease is better...
wira headlights as we know it has a V shape light projected on the road which is not very evenly distributed and hence causes an inefficient way of lighting the road, i personally find this annoying and the root cause of the problem seems to lie in the way the reflectors were designed
what i wanna ask the masters here is
if i change to crystal headlights
will the V shape projected lights be there?
is it really brighter than the original headlights as claimed by those sellers?
to those...
