bro,
parts for honda vtec parformance.
1. new OBX throttle body 70mm (made in usa/original) RM900
used HOLLEY throttle body 68mm (made in usa/original) RM680
(used on B/H/F/ZC)
2. new MSD PRO distributor cap and MSD ignition coil (made in usa/original) RM900
new MSD SCI PLUS ignition control system (made in usa/original) RM2300
(its got launch control/4-6-8 cyclinder engine with distributor/up to 50000
volts/nitrous retard/soft rev limiter/multispark)
new MSD 8207 power coil SOLD
used MSD super conductor ignition spark plug cable RM380
used MSD 7AL2 PRO DRAG/TRACK ignition control RM2000
(its for 4-6-8 cyclinder engine with distributor/up to 55000 volt/nitrous retard/soft rev
limit/multispark)
used MSD 7 series PRO power coil RM750
(up to pro 55000 volts)
3. used ULTRA MDI ignition system for without using distributor kit. RM2600
(its full kit with without leave anything from new kit, just plug and play only. menu book
also write can use on other car but its need for the pro installer)
4. used SKUNK2 PRO SERIES camshaft stage2 with valve spring together. RM3500booking
(its PRO SERIES camshaft for high rev 10k with valve spring together, no ti retainer. use
around 5000km only, owner plan to change car. camshaft and valve spring in mint condition)
5. used ATS gear close ratio 3-4-5 gear. SOLD
(3rd 1.652 4th 1.308 5th 1.033, here the calculate. its ori ATS parts.)
6. used B series 4.2 final drive. sold
(its ori JDM parts, just plug and play only)
7. used B18C TYPER manifold with ALFA throttle body 70mm. sold
(its working on a car, complete all sensor place to use)
8. used B18C intake manifold, throttle rebore 68mm, just without injector. SOLD
(its complete all the thing and just miss injector only)
9. used APEXI POWER FC standalone ecu, full set with harness 02 to 01 ecu. SOLD
10. ORI MUGEN sports absorber. RM1000
pls see pics at http://www.flickr.com/photos/28257414@N03/
pls contact 017 5102600
(used on B/H/F/ZC)
limit/multispark)
