Rub-Angina (Rubicon) Competition mono-block amplifier ( open box )
Very very good condition ,made in USA.handcrafted..for competition use..very powerful.
Very very rare in market , a one of exclusive sale , competition series mono-block amplifier from soundstream.
Brand new condition , a must have for ice fans.
Seliing cheap , brand new is Rm2300 now selling Rm1000 nego
Specifications
Fully regulated, MOSFET power supply
RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Auto High Current™ Matches amplifier for virtually every load application
Chassisink™ Transistors are located between circuit board and heatsink for optimal heat dissipation
Triple Darlington output circuitry
Vortex induction fan for thermal management
Bi-Linear built-in selectable 2-way crossovers for amplifier and RCA line output
Continuously variable 12dB low-pass crossover (30Hz to 4kHz)
Continuously variable 12dB high-pass crossover (30Hz to 4kHz)
Hawkins Bass Control™ Proprietary bass equalization topology
Harmonic Bass Alignment™ Produces tighter and more accurate bass reproduction
Trident™ amplifier protection topology
IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status
Balanced Line inputs for the highest level of noise rejection
Platinum RCA input and output
Platinum power inputs
Tri-mode operation
10Hz – 30 kHz frequency response
>100dB S/N ratio
• >200 Damping
0.15 - 12.0V Input sensitivity
0.05% THD
# RUB-ANGINA
# 1 X 100 RMS 4 Ohm
# 1 X 200 RMS 2 Ohm
# Dimensions 7" L X 2.25" H X 5.25" W
Please call : Ravin 012-9197949
Specifications
Tri-mode operation
>100dB S/N ratio
• >200 Damping
0.05% THD
# RUB-ANGINA
# 1 X 100 RMS 4 Ohm
# 1 X 200 RMS 2 Ohm
