monsh
yeah, TS didnt give any feedback after last discussion .
we told him check the pump .
possible dead pump .
sorry for the late reply, the pump is working good, the temp raise cause of blockage of metal pieces, after washed the radiator, it's good... but problematic is the metal pieces show up again.. highly suspected is the impeller of the water pump eroded and get fragile due to previously use only plain water without coolantyeah, TS didnt give any feedback after last discussion .
To TS (Thread starter), the Koyo 2 layer aluminium radiator with top and black fibre comes with 0.9 bar radiator cap. I believe it was brought from an online trader here.
Used it and notice the temperature a bit high on highway run. Changed to the 1.1 bar ND- Nippon Denso radiator cap (original pressure recommended by Honda from factory), the temp definately not as high as using 0.9 bar.
Why not try to change to correct radiator cap pressure first?
Similar threads | |
