thanks for the reply , for a moment I though it's just quite.
I truely agree that life will be a lot easier wide a 2k wide band
and muilty 10ks(or 100ks?) dyno mechine , but they are really out of my leage
right now.
by your reply few points are comfirmed
1. highsest EGT happened at around stoi ( AFR 15) , add or remove fuel from
there will lower your EGT.
2.wide band need calibration
http://www.megasquirt.info/PWC/calib.htm
3.no , EGT meter is nOt better than a wide band sensor
4.going leaner than stoi will not increase EGT, but is dangerous because detonation
(pinging) creeps in.....
5.I really like your last words:
"I would suggest that mixture meters and EGT gauges are complimentary. EGT
gauges have the advantage of working long term with leaded fuel which will clog
oxygen sensors. EGT gauges are widely used to set mixture on engines used for
steady state high power applications where operation has been carefully documented
such as in aircraft. The choice would depend on the application. Both are better if you
can afford them."
I think we read the same books here , because the EGT tunning idea is from a
airplane tunning corp:
http://www.gami.com/future.html
the story is really simple as I'm trying to built a lean burn machine with water injection.
the whole idea is to save fuel (money) , as I do not plan to 5k modification to save
on 200 bucks monthly fuel . Use what I have and what I can get easily(cheaply),
as I already have the narrow band sensor in my k3-ve exhause , I have thermometer
minus a high temp thermocouple( my thermocouple max at 300 C) , I bet there is
whole lot of data hide in my ecu waiting for me to do some mining , or even a EGT
reading.
btw, I do a search on wide band o2 sensor price , some where say a bosch LSU 4
is for sales at US 80. But how come tuning package price listed here is rm 2k? will
a high end voltmeter works with LSU 4.
again thanks for the reply
ps :EGT is quite high graded for me already, as recently I'm trying to tune the AFR
with my ...... nose , works better after a few drinks though.
