Toyota Altezza Marketplace Links - Parts & Others
10% off to all Altezza Club (FB & ZTH) members with validity from now till 31AUG2012.
Kindly provide your members the coupon code "tezzaclub" without the inverted commas to be input into our website checkout page upon checking out. It will automatically apply a 10% discount. Kits take 1-2weeks to be produced.
Lexus IS
Special request to produce kits in Carbon fiber can be arranged. Email: [email protected]
Altezza 3SGE Engine with Auto GearBox Rm1800
Altezza Power Steering Pump
Altezza Air Cond Pump
Altezza Alternator (Starter)
Altezza Front n Rear Caliper n Rotor Set . rm500
Altezza 4.1 FD Differential .
Altezza 4 x pcs 17" Original Sport Rim with center cap rm800
JZA80 Supra Front and rear calipers , rotor set rm2200
Brembo Evo 8 Front and Rear calipers with rotor . rm3200 .
JZX100 Aftermarket Japan Turbo Manifolds rm1200
JZX100 Cusco Front Under 3 point member brace rm300
JZX100 Cusco Rear Sway Bar rm250
JZX100 Cusco Front Adjustable Upper Arm rm500 (Booking) 11/11/13
Sard original R2D2 Blow Off Valve . 99% like new used less than 1000km . rm300 .
HKS Actuator .
All Stuff in Good and Running Conditions .
Thank you . Updated 11/11/13
Intrested Pls Call: 013-2373772
Or Whatsapp : 019-2963772
SXE10 G1 6MT CKD half cut NEW ARRIVAL
http://www.zerotohundred.com/newfor...sxe10-g1-6mt-ckd-half-cut.html#post1064096885
SXE10 altezza TOM's lower engine bar NEW ARRIVAL
http://www.zerotohundred.com/newfor...zza-toms-lower-engine-bar.html#post1064096888
SXE10 rear trunk mat NEW ARRIVAL
http://www.zerotohundred.com/newfor...7815-sxe10-rear-trunk-mat.html#post1064096879
TRD semi bucket seat for SXE10 NEW ARRIVAL
http://www.zerotohundred.com/newfor...emi-bucket-seat-for-sxe10.html#post1064096880
SXE10 altezza rear trunk netting NEW ARRIVAL
http://www.zerotohundred.com/newfor...ltezza-rear-trunk-netting.html#post1064096882
SXE10 NEO bumper with oem grille n fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...ith-oem-grille-n-fog-lamp.html#post1064096881
SXE10 rear bumper with lips NEW ARRIVAL
http://www.zerotohundred.com/newfor...e10-rear-bumper-with-lips.html#post1064096884
SXE10 yellow eye fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...sxe10-yellow-eye-fog-lamp.html#post1064096886
SXE10 oem fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...417823-sxe10-oem-fog-lamp.html#post1064096887
SXE10 rear carbon fiber register plate cover NEW ARRIVAL
http://www.zerotohundred.com/newfor...iber-register-plate-cover.html#post1064096889
SXE10 rear oem spoiler NEW ARRIVAL
http://www.zerotohundred.com/newfor...26-sxe10-rear-oem-spoiler.html#post1064096890
SXE10 4.556 TRD ratio with ATS 2.0 way LSD NEW ARRIVAL
http://www.zerotohundred.com/newfor...atio-with-ats-2-0-way-lsd.html#post1064096871
18" work VS sport rim with tire NEW ARRIVAL
http://www.zerotohundred.com/newfor...rk-vs-sport-rim-with-tire.html#post1064096872
SXE10 altezza rear axle drive shaft NEW ARRIVAL
http://www.zerotohundred.com/newfor...zza-rear-axle-drive-shaft.html#post1064096873
SXE10 altezza front lower arm with ball joint NEW ARRIVAL
http://www.zerotohundred.com/newfor...lower-arm-with-ball-joint.html#post1064096874
SXE10 altezza upper arm with ball joint NEW ARRIVAL
http://www.zerotohundred.com/newfor...upper-arm-with-ball-joint.html#post1064096875
SXE10 altezza lower arm with bush NEW ARRIVAL
http://www.zerotohundred.com/newfor...tezza-lower-arm-will-bush.html#post1064096876
A thread every 60 seconds
