SuperPro Polyurethane Bushings for Toyota Altezza/Lexus IS200
1) Front Strut Bar To Chassis Mount Kit (Caster Bushings) SPF3040K 6 Bushings, 2 Inner Tubes, 2 Outer Shells. Standard replacement. RM520
2) Front Sway Bar Mount Bushing SPF2816-27K 2 Bushings Replaces OE# 48815-53010 = 27mm. RM90
3) Rear Control Arm Lower-Inner Bushing SPF3036K 2 Bushings, 2 Inner Tubes, 2 Outer Shells. Standard replacement. RM390
4) Rear Control Arm Upper-Inner Kit SPF3043K 8 Bushings, 4 Inner Tubes Standard replacement. RM390
5) Rear Sway Bar Mount Bushing SPF2817-14K 2 Bushings Replaces OE# 48818-30010 = 14mm. RM90
6) Rear Toe Control Arm - Inner Bushing SPF2786K 4 Bushings, 2 Inner Tubes. RM205
7) Rear Trailing Arm - Front Bushing SPF2784K 2 Bushings, 2 Inner Tubes. RM205
8) Rear Trailing Arm - Rear Bushing SPF2785K 4 Bushings, 2 Inner Tubes Bushing located in hub. RM205
All ready stock. 1 set only.
012-2047338
Bdr Sri Permaisuri
012-2047338
Bdr Sri Permaisuri
