err, COW..to answer ur question..this model of GSR was first introduced around October 1995
GENERAL
Body type: Sedan
Drive: FULL 4WD
Transmission: 5 speed manual
Displacement, cc: 1834
Frame: E-CM5A-SNGF
Price of new car, thousands yen (Tokyo area): 2403 (~$20000)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm: 4290 x 1690 x 1405
Interior dimensions (LxWxH), mm: 1805 x 1430 x 1175
Wheel base, mm: 2500
Treads (F/R), mm: 1450 / 1460
Ground clearance, mm: 155
Curb vehicle weight, kg: 1240
Gross vehicle weight, kg: N/A
Seating capacity, persons: 5
Doors number: 4
Min.turning radius, m: 5.4
Fuel tank capacity, l: 50
ENGINE
Engine model: 4G93T (turbo)
Max.power (Net), kw(PS)/rpm: 205 ps (150.78 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 28.0 kg*m (274.59 N*m) / 3000 rpm
Power density: 6.05
Engine type: Serial 4 cylinder DOHC16 valve IC turbo
Engine information: N/A
Fuel system: ECI-MULTI (electrically controlled gasoline injection)
Turbocharger: Turbo with intercooler
Fuel type: Unleaded premium gasoline
LEV system (Low emission vehicle): No
Compression ratio: 9 ;)
Bore, mm: 81
Stroke, mm: 89
Final gear ratio: N/A
Fuel consumption at 10-15 modes, l/100km: 8.1
Fuel consumption at 60 km/h, l/100km: N/A
CHASSIS / TRANSMISSION
Power steering: Yes
Tires size, front: 195/55r15 84v
Tires size rear: 195/55r15 84v
Braking system, front: Ventilated disk
Braking system, rear: Disk
Suspension system, front: McPherson strut
Suspension system, rear: Multiple link
There, hope this will help you :)
Regards;
